It appears to me only the blue portion glows red.My new CF just arrived. I am quite happy with the watch and the new bezel insert. Also lights up completely red under UV light... only thing that is bugging me, is the magnification of the lens being too high (see pics next to my gen gmt). Does the crystal sit too high due to a too thick crystal gasket or is it the crystal itself? If it's not the crystal itself, might it be possible to sand down the gasket or does anyone know where to get one that will fix this issue?
you might be right... from afar it looks like the whole bezel is red, but if you hold the UV light against it very closely it's only the red part actually glowing.It appears to me only the blue portion glows red.
Clean’s batman is as identical as possible and more genlike than the new pepsi for sure. But the new pepsi looks absolutely great as well. In the end it’s just a matter of taste..is clean the closest one to gen for batgirl? I’m torn between the Pepsi clean upgraded insert and a batgirl. I don’t know who makes the closest rep for batgirl please chime in. I would appreciate the input. The ks
It's a combination of both... I have OCD for this as well... cyclops magnifies too much and the typo is a bit too largeonly thing that is bugging me, is the magnification of the lens being too high (see pics next to my gen gmt). Does the crystal sit too high due to a too thick crystal gasket or is it the crystal itself? If it's not the crystal itself, might it be possible to sand down the gasket or does anyone know where to get one that will fix this issue?
Its both. The crystal has a wrong magnification (And its overall shitMy new CF just arrived. I am quite happy with the watch and the new bezel insert. Also lights up completely red under UV light... only thing that is bugging me, is the magnification of the lens being too high (see pics next to my gen gmt). Does the crystal sit too high due to a too thick crystal gasket or is it the crystal itself? If it's not the crystal itself, might it be possible to sand down the gasket or does anyone know where to get one that will fix this issue?
So in the end is it correct mag and gen spec bevel height? Wondering pressure testing at that point as well.Its both. The crystal has a wrong magnification (And its overall shit) AND the gasket is to high.
I installed a gen crystal on mine. Gen gasket was to low, so i sanded down the rep gasket.
All my work info is at the end of this tread: https://forum.replica-watch.info/th...x-the-bezel-on-a-clean-gmt-master-2.10668398/
Post 312, https://forum.replica-watch.info/th...ezel-on-a-clean-gmt-master-2.10668398/page-16So in the end is it correct mag and gen spec bevel height? Wondering pressure testing at that point as well.
While it seems like it can vary quite a bit, there’s multiple people suggesting the newest clean in the last few weeks accepts Gen gasket and xtal seamlessly. I’m about to cut my losses and run back to Daytona
Well i had one on my table 2 days ago, and the crystal height and magnification was correct with the gen gasket. But the gen gasket id to fat for the retainer ring, so you are back to sanding the rep gasket downWhile it seems like it can vary quite a bit, there’s multiple people suggesting the newest clean in the last few weeks accepts Gen gasket and xtal seamlessly. I’m about to cut my losses and run back to Daytona![]()
This is why I just never trust clean. It’s always something.Well i had one on my table 2 days ago, and the crystal height and magnification was correct with the gen gasket. But the gen gasket id to fat for the retainer ring, so you are back to sanding the rep gasket down![]()
That’s how it is with every single factory, not just cleanThis is why I just never trust clean. It’s always something.
Does this go for the batgirl with the jubilee strap as well? I’m leaning towards the clean batgirl.Clean’s batman is as identical as possible and more genlike than the new pepsi for sure. But the new pepsi looks absolutely great as well. In the end it’s just a matter of taste..
Do a bit of research here on this forum, instead of just asking. There is so much information available to those interested.Does this go for the batgirl with the jubilee strap as well? I’m leaning towards the clean batgirl.
Very true. I have clean’s VTNR with a gen xtal en a geb xtal waiting for the pepsi, when it arrives. Probably will add a gen date wheel as well. To me, the date and the bubbel have to be perfect.Do a bit of research here on this forum, instead of just asking. There is so much information available to those interested.
Every rep falls short when you put it next to a gen. I have a gen batgirl, and if you put a stock Clean next to it, I can easily tell them apart. If you Franken the clean with gen crystal, datewheel and hands, it will get difficult to tell them apart. If you slap on a gen inlay, it will be VERY difficult.
