- 7/8/16
- 2,597
- 800
- 113
I actually think that you also have to ar coat both sides of the crystal where the cyclops sits.
Sent from the RWI mobile app
You guys need to read and understand how an AR coating works.
The underside of the crystal is coated where the cyclops sits and the top of the cyclops itself.
That's what i was going for.You guys need to read and understand how an AR coating works.
Here is a rep vs gen Sel comparison:
The one with the shiny scallops is gen.
Up right and down left is gen. Sorry for the mixup.i dont understand? so just down left is gen, right?
Still using the 2mm spring bars?
Looks like your 3rd illustration.
That's some serious Scott brite used on Jen.
Sent from my SM-G930F using Tapatalk
It's with the 2mm springbars. Didn't have time to go and buy 1.8mm to make the change.yeah, mixup.[emoji23]
before and after 1,8mm bars. :rollingonthefloor:
obvioulsy not!
looks like hes playing around with filters(and lighting) to fool us.![]()
For some reason the mobile app didn't show your prevoius posts[emoji12]
Yes, plastic and grinded springbar on one side and plastic, grinded and bent springbar on the other side.Sel looks really good.
So this is the plastic and grinding the springbars to achieve this?
Excellent result.
I don't think the black hole is a huge tell. Look at all the gen pics on TRF. The cyclop only black holes in certain angles. The rest look more or less the same.
