Noob V7 SEL fix DIY
Spatiumtemporis
2,597
801
Is this your pic op? If so I'm correct you have a v6s
The lugs are the giveaway if the rehaut engraving is not clearly visable .so guys that's a tip for you how to spot a v7 or v6s.so you accually get what your buy.and not something else.
Yes those are my pics. What about the bracelet ?
Sent from the RWI mobile app
Spatiumtemporis
2,597
801
could you please explain how you fixed the dial issue??
Thx
You have to open the case back and loosen the movement. There are 2 screws you need to twist in order to do this. Here is a pic showing the screws:
You don't have to unscrew them all the way, just them give them a 180 degree spin in either direction and you will unlock the movement along with the dial.
Now, using a flat screwdriver or a plastic tool slightly push the movement in the desired direction until you get the rehaut crown aligned with the 12h (60 min marker) .
WARNING : do not tilt the watch while the locking screws are unlocked because the movement will fall out of place and can damage the crown tube.
You can check if the correct position is achieved by lifting the watch and looking at the dial from underneath.
Good luck !
RHEFL
524
50
ITALY
[MENTION=83013]smoke[/MENTION] bro full pm
Inviato dal mio iPhone utilizzando Tapatalk [emoji634]
livinglegend510
64
Good luck !
Thank you so much!!!!! gonna try it tomorrow
kiz1
704
45
My 1.8mm Springbars arrived!!
What do you think of my SEL? I think this looks damn good!!
Sent from my SM-G930F using Tapatalk
pengo
2,528
254
do u still have the plastic-mod underneath?
damn i may should have bought no-date(no tell on cyclops). but i like the date so much and anyway i have the telling 2836.
so next time for me: no date SA3135! :)
does a hulk no date exist?
Join3d
318
137
Hulk no date doesn't exist.
kiz1
704
45
Yes, plastic underneath. Pins wedged in to the holes with cocktail sticks.
Slight bit of play due to the thinner pins in the lug holes which I will fix with some blu-tak!
No date hulk doesn't exist!
kiz1
704
45
Right, my final adjustment, I wasn't happy with cocktail stick in the watch incase it attracts moisture and also I wanted to take away the bit of play in the SEL.
Here is my version of the solution. Many thanks to the OP for triggering the ideas.
I used insulation tape around a 1.8mm Springbar. Then using a craft knife cut half of it off so there is a wedge on one side.
Then used three layers of masking tape on the inside of the SEL.
Result is this. With a lot less movement. Probably the same amount that I had with the 2.0mm Springbars.
I'll consider this fixed from my end!!
kiz1
704
45
Rehaut alignment done as per Op's instructions.
5 min job, loosen 2 screws, move slightly to left or right, and tighten.
Thanks again [MENTION=132141]andrei01[/MENTION]
Now waiting for your black hole fix!! ;-)
