Noob V7 SEL fix DIY
Spatiumtemporis
2,597
801
Right, my final adjustment, I wasn't happy with cocktail stick in the watch incase it attracts moisture and also I wanted to take away the bit of play in the SEL.
Here is my version of the solution. Many thanks to the OP for triggering the ideas.
I used insulation tape around a 1.8mm Springbar. Then using a craft knife cut half of it off so there is a wedge on one side.
Then used three layers of masking tape on the inside of the SEL.
Result is this. With a lot less movement. Probably the same amount that I had with the 2.0mm Springbars.
I'll consider this fixed from my end!!
Sent from my SM-G930F using Tapatalk
Kiz your SEL looks great. Congrats!
Sent from the RWI mobile app
Spatiumtemporis
2,597
801
Rehaut alignment done as per Op's instructions.
5 min job, loosen 2 screws, move slightly to left or right, and tighten.
Thanks again [MENTION=132141]andrei01[/MENTION]
Now waiting for your black hole fix!! ;-)
The dial is spot on ! Glad i could help.
Black hole [emoji6]
Smoke
14,093
2,220
The sel angle is wrong it should start near flush and taper away .yours is tapering the wrong direction if you know what I mean
Tigerdragon
7,292
1,687
I still hope Noob fixes the bezel color :( when you are at dinner its really a big tell.
Smoke
14,093
2,220
The v7 insert paint is too white
V6s paint is too grey
Rx4Time
12,369
12,039
I'm sorry to hear that. Time to pick up a serviced yuki?
maxracingshox
2,581
287
if it just doesn't keep time well, chances are there's nothing broken and it just needs a good service!
