- 9/10/20
- 588
- 717
- 93
Depending on the watchmaker and the gasket used the magnification changes even if DW, crystal and gasket are all Gen. Your watch is very GEN like. Magnification is perfect
Yes i heard about this too, they shave the gasket a little to make the magnification of the DW a little smaller.Depending on the watchmaker and the gasket used the magnification changes even if DW, crystal and gasket are all Gen. Your watch is very GEN like. Magnification is perfectCongrats and wear it in good health.
beautiful photos. May I know what you use to photograph?V3 insert is the best I have seen.
I have the Gen MK3 and GEN MK2
Bellow are comparison photos of the GEN MK3 (left) and V3 insert (right)
In the photos you can see a slight difference but in reality the difference is very small. Two of my friends have Gen MK3 and all 3 of us have slightly different colors.
If anyone wants any more pictures feel free to ask.
Thank you. iPhone 16 pro max regular settings. Sitting on my bedbeautiful photos. May I know what you use to photograph?
What size gasket did you use? Still looks a tad too magnified?
Read it again, especially post 8, where KJ2020 is kind enough to do a photo guide, there is no way to misinterpret thatHello,
I received my Pepsi and contemplating increasing the bezel lip.
I went through this thread https://forum.replica-watch.info/threads/cf-pepsi-bezel-lip-mod.10076178/ and understood the materials needed. But I'm unsure the way to do it, do you guys recommend doing it manually by hands or with a Dremel?
I suppose the way is to grind this red zone downward with the sandpaper to make it more flat ?
Appreciate the help.
Thanks, it makes thing clear now after I reviewed the original thread, thanks mate a lot.Put a sand paper on the table, and hold the bezel and sand it slowly until the bezel lip is flat
I'd be down for more pictutes in heavier light to show the brighter color differences!V3 insert is the best I have seen.
What size gasket did you use to get “gen like”?Best that i could get without gen parts:
- Bezel lip mod
- Clean Crystal(good one)
- Aftermarket gasket(gen crystal height achieved)
- Rehaut Polished
- Bezel rotation fixed(as gen sound and action)
- Waterproof
Nice build. Are you saying with the 2.7 gasket its still too much? Is 2.7 the lowest you can use without touching the seconds hand?Clean v3( China calls it v2)
Gen datewheel
Gen crystal
2.7mm gasket ( to match gen mag)
CNC bezel as the clean bezel scallops are too sharp
Bezel lip mod
