DonkeyHoTay
Cockwomble Misfire Specialist
17/3/23
192
237
SE USA
If it is seized, be aware in the US your address will be flagged and monitored more closely.
interesting! I just got delivery of a clean 126500LN Panda and a VSF 126506 Platona with extra weight….. same box and no problems with shipping. Fingers crossed on my GMT meteorite re-do.
DonkeyHoTay
17/3/23
192
237
SE USA
Any pictures........ Please!!
If you mean pictures of the Clean Pepsi v3 franken with the Meteorite dial, I will send when I get QC from TD.
Unfortunately I had to RL the QC the first time around because of what looked like scratches on the bezel and/or rehaut - maybe installation mishap during dial and crystal upgrades:
TD made it right with part replacements, but it all went to shit when the package got stuck in Malaysia. Hoping that round 2 works out!
peterpl
4,827
857
why the F cant they fix the DW mag? Its been released for so long. What's the issue here simply the gasket size? I dont get it how hard it is to rectify this.
Reactions: Mr.Paneristi
MrButterfield
37
29
I wonder, if they change the gasket size to lower the crystal (and thus, the magnification), does the crystal protrusion now not match gen? Or, is it closer to gen?
2841
Daytona Hoarder
2,338
2,260
Then the crystal hits the second hand.
So for them to fix the issue once and for all, they would need to fix the gasket and the height of the second hand
Mark1937
4,465
4,005
The gen case has a lower flange than the CF one, the gasket supplied with the gen crystal is 2.2 mm high. These gen crystal + gen gasket measurements are produced by Rolex to have the right glass height (a little protruding from the bezel) and the correct date magnification. I just assembled it including the gen case. As you can see the dial in the gen is less sunken. The gen hands do not touch the glass in this case but it must be said that my 3285 movement comes from a CF V1 (in the first series there was no problem with the hands touching the glass). This is the result with all gen parts (except movement):
2841
Daytona Hoarder
2,338
2,260
I had 3 different CF v1, 2 of them touched the glass, 1 didn’t 😂😂😂 It just luck of the draw sometimes
Fusible
638
1,063
Correct! Shaving the seconds hand generally works but yes it’s annoying to immediately send a new watch to the modder. For these reasons I prefer to go with C+ as they have a better hand stack height without the DD movement.
DonkeyHoTay
17/3/23
192
237
SE USA
This thread is making me want a plain jubilee clean v3 Pepsi. But should I get the deep crystal for it…:unsure:
Ordered it from my favorite TD... keeping the clean crystal on it - trusting the views on this thread that there is no need for a deep crystal upgrade and that OOTB it's good to go!
