derjenigewelcher
Watch enthusiast
10,065
13,903
Switzerland
I have ordered CF GMT Pepsi with V2 insert and oyster bracelet and my dealer has presented this interesting piece. The watch is turned to be a fake CF Pepsi (check movement pic below) but I say it is interesting because of the following reasons:
1- Correct CF bracelet code (1NQ)
2- Correct CF SN on Rehaut ends with L6V6
3- V2 insert which completely turns red under UV light!!
Thought to post my findings here so the community is aware!
Well mate these stickers can be bought on the market in sets. so this watch may be whatever it may be, but no CF. Thats the Reason we (and you) should buy at TDs place and not at wechat dealers for 30% less;)
JOSswag
152
134
They really fake the fake😂
Reactions: engbanna1
Scottymagic
2,024
1,113
V2S below: will change to a V2. Plating isn’t great as can see the red through the numbers and the red is a bit orangey.
Posting for info:
JOSswag
152
134
Hi Sorry for the question. So Ive had put the gen crystal 7035-J1 on my C+ with 2.3mm gasket height. But it turns really bad especially on the cyclops reflection and makes the date looks bit blurry, it happen in any lighting conditions and no blackhole as well. Does the wrong size gasket causing it all the problems? Should I put 2.7mm gasket on it to fix the problem? Thank you
Mark1937
4,497
4,039
the reflection seems to be a glass problem, as far as the gasket is concerned it is preferable to use the 2.70, the date will have the right magnification (and will not be small) and the crystal will protrude the right amount from the bezel.
Reactions: JOSswag
JOSswag
152
134
Is there any way to fix the problem Sir? Or did I received the fake gen crystal maybe? 🥲
Akilles
Lord Commander
1,337
1,790
The North
Posting for info:
Im all confused. Been asking Ctime once every 5 days or so when they will sell the v2s but he says they dont sell it yet due to insert problems. Are you sure this is not v2?
Akilles
Lord Commander
1,337
1,790
The North
Adding a gen insert, gen crystal (with gen gasket) will not always make it look gen on a rep.
If there is a difference in rehaut height in the rep the DW typo will end up blurry or in wrong size. Those parts you will need to eye measured/QC:d by you.
My modder installed gen crystal/gasket on my Clean 116613LB. Looked bad so he switched to another gasket and it looked much better
Reactions: JOSswag
JOSswag
152
134
I believe those are C+ V2 with v2s insert. Based on the serial code that start with 897C.
Scottymagic
2,024
1,113
100% he had one that he offered to me above
Reactions: Akilles
woogooboogoo
21/11/19
I consider buying the recently updated cf pepsi, however I can't seem to notice that the date is over magnified. I've read through this thread, which explains that this might be an issue. As of today, did this issue only affect some watches or is it a batch flaw that affects all new v3's?
Mark1937
4,497
4,039
yes it is an obvious flaw. But just change crystal and use the right gasket
Cheese it
32
17
I’m using a Gen gmt crystal with stock cf gasket and it’s still the same as before. The Gen 2.3mm gasket doesn’t work. Well it works the date is perfect. But the hands touch the crystal so it stops the entire movement.
Mark1937
4,497
4,039
with the gen gasket 2.30 the gen crystal will not protrude like this... to make it protrude and give the right space to the hands you need to use a higher 2.70 gasket. Mine is a clark 2.70 but in reality it measures 1.65
Reactions: AG91 and JOSswag
Endez
1,189
1,312
Just received my V2, looks really good. I didn’t have the chance to compare with gen since I have, but will do shortly
Reactions: AG91
