- 14/10/19
- 2,384
- 10,274
- 113
DW of this watch is 6.9 open for sillan 3135What date wheel is this?
Older BP 16610 cases have a polygonal wire clip bezel.I wanted to ask how this case and build compares to the BPF 16610 ?
Thank you !Older BP 16610 cases have a polygonal wire clip bezel.
The newer ones have a bezel structure like a 6-digit case.
There is also a rehaut Rolex engraving.
ARF/RAF or sillan 16610 cases have the same bezel construction as GEN.
Therefore, if you want to build older 16610s, the ARF/RAF or sillan 16610 case is more suitable.
If you drill through holes in the lugs, you can use 93150.
Who is RAF/ARF please? ThanksI purchased this item from Sillan which I believe is the RAF/ARF 16610 case from the Aliobaba website.
It arrived today and I am going to try out a few things.
Factory of the case.Who is RAF/ARF please? Thanks
Could you give me the contacts or websites please?Factory of the case.
Alibaba advertised it for $200.00 and Aliex for $444.00 what the heck I can get the whole watch assembled from ARF for $400OP mentionned AliBaba vs AliX
maybe it's the same case
First of all, you need to have a lot of knowledge.No thru holes or did you add them
thanks
