I purchased a Sillan 16610 case from Alibaba.
Raymond
209
68
Serial number starting with m would indicate this would be a 2007 or 2008 ,meaning there should be a engraveing on the Rehaut , trying to figure that out if I am correct or wrong ?
bowtiefanatc
1,126
1,078
There is an engraved option if that’s what you want.
trash3939
2,633
11,732
Originally, M number 16610 is stamped on the rehaut.
In this case, it is a replica.
ARF had some with and without engraving on the rehout.
It is not accurate.
JKF, for example, has a 5513 case with 1680 engraved on it.
Reactions: Karbon74
Raymond
209
68
It is not accurate.
Thanks sir appreciate it . Trying to figure the best case for 16610 build after my 5513 on the way from jkf.
Caboose
1,702
2,482
Dremel with 0.8mm bit from the inside of the lugs to get the pilot hole. Then 1.25mm from the exterior with a small drill press with high speed.
For the initial Dremel bit, how are you getting the bit to come out straight and not at an angle? Tight fit between the lugs!
bowtiefanatc
1,126
1,078
Tape the back of the case, make sure the chuck doesn’t hit the lug. It will be a slight angle. That’s why I use a 0.8mm bit, it reduces the angle. Then you widen the hole with the 1.25mm from the exterior.
