Its the correct hont.Shine a UV light on the insert and see. The change in platinum filing definitely looks like Xing. I know that Fake Clean GMTs don't have UV light but they use a VR3186 and have a Y2L3 serial, at least on the ones I've seen. The ball bearings holding the rotor definitely make this look like a SH3285.
Can you check the contact info you have for Hont against what's in the TD section here?
Edit: a few pages back it says that Clean has been using both Y2L3 and L6V6 serials
So it's the correct sticker, serial, bracelet and everything. EXCEPT the movement and insert seem to be swapped out... I have messaged hont. We will see what he says. I was really disappointed, I had a Gen crystal and DW Ready to install.
I am probably gonna go ahead and install anyways.
Something interesting I noticed:
The VR/SH 3285 in this has a keyless of a 3135 vs 3235. The VR/SH 3285 in the GMF explorer has keyless of a 3235.
I am curious if this VR 3285 would have the same issues as the VR 3285 in the GMF explorer...
