0ffcamber
64
58
U.S.A.
Here’s what happens to a new Clean V3 Pepsi bezel when a bit of garage grease gets smeared across it.
The platinum colored paint is not very resilient.
As New
Grease Damage
Note to self “remove watch while fixing stuff in the garage”.​
Reactions: Reaps
25,245
Here’s what happens to a new Clean V3 Pepsi bezel when a bit of garage grease gets smeared across it.​
The platinum colored paint is not very resilient.​
As New
Grease Damage
Good to know. Plat plating looks damaged. I assumed you already washed it vigorously with some liquid wash soap for dishes?
You can try and do a DIY fix by getting a silver sharpie and filling in the numbers yourself. It won't look quite like the original but hey it beats spending $200 for another insert.
0ffcamber
64
58
U.S.A.
As soon as I wiped off the grease with a microfiber cloth the platinum paint came off.
I did grab a dab of soap and water to fully clean it which worked but a bit more paint came off too.
It was a learning experience for sure. I actually believed the paint was baked on but I wasn’t really sure until now.
I’m on the hunt for a replacement.
25,245
This was talked about in the very first batches of the insert actually, some members had the platinum plating peeled off, but then it was retested with soap and it didn't happen,
So it seems it is an issue, the platinum plating is reactive to certain chemical compositions,
aHero
Watch Bro
4,453
6,594
I use this instead:
Richard 26
32
29
Lighter fluid is great at cleaning up oil/grease. Note sure if it will react with the paint but might we worth a shot
aHero
Watch Bro
4,453
6,594
Wait i must be behind lol Clean went away from the pastel inserts? Damn
Reactions: Reaps
btrizzy1
200
147
I have a Xing V5 Pepsi Bezel that I am looking to swap. Anyone have a video on how I can do that? Or is it better to send off to a watchsmith?
aHero
Watch Bro
4,453
6,594
It’s a simple DIY just be careful. I’m not experienced and I’ve done this over a dozen times without cracking the ceramic.
btrizzy1
200
147
Do you have guide or video that you followed before doing it?
mini88
228
176
which of the current pepsi models look like the one on the right? i like the actual blue color instead of the darker/navy blue on the left.
Zeta7
1,148
1,174
I cracked the insert on my 41mm vsf submariner and been gun shy ever since. I don’t know if there’s any connection between them but be careful
Reactions: Reaps
25,245
The rep ceramics are extra thin compared to gen so alot of care must be taken with them. My personal watch maker has cracked 1 sub insert and told me he got sweaty removing the one for my GMT lol
JimmyD750
Official RWI Reddit reporter.
767
311
St. Louis, MO
99% isopropyl alcohol is best, as it leaves absolutely zero residue. Lighter fluid leaves an oily residue which is hard for paint to adhere to in the future, when he redoes the markers (this mod is what I’d call semi-permanent). You can find 99% on Amazon as cheap as $7, but I use this as it’s a higher grade:
