Well, I watched a video too, but maybe it was the wrong oneIm never setting the watch backwards. Just my luck I will have an issue. I’m still re watching a video beforehand just to be sure before I set.
![Face with tears of joy :joy: 😂](https://cdn.jsdelivr.net/joypixels/assets/6.6/png/unicode/64/1f602.png)
I think you're overthinking this a bit.. In my view you have a few options:Thanks for your response! Well, now he is telling me not to turn it backward at all because it will break the watch. I even asked if I could do it in the 2nd or 3rd position of the crown, but the answer was not to turn it backward! The question is, what watch did they send me? Supposedly, it's a CF V3 with a DD3285 movement. Since it's running slow, I'll take it to a watchmaker to adjust it, and maybe he can do something about the bezel too because it has a lot of play. I just wrote to Ctime asking what kind of watch this actually is. I'm curious about his response.
Thanks for your response. I'll check the bezel myself and try to adjust it. I also thought the date could be set in both directions, but Ctime wrote this "The factory don't recommend set the date backward, they said will damage the movement"3285 is absolutely in charge to set the date backwards. Dont worry.
And for backplay of the bezel there is a fixed thread in the forum here, no need for a watchmaker![]()
Well i just told you my opinion. I bet the factory says this so they dont have to provide warranty. I never did something else on VR3186 or DD3285 or SH3285. Maybe a watchmaker can tell if you should not do that on those clonemovements.Thanks for your response. I'll check the bezel myself and try to adjust it. I also thought the date could be set in both directions, but Ctime wrote this "The factory don't recommend set the date backward, they said will damage the movement"
That's why I asked him what watch he sent me. Is it CF and definitely DD3285? There shouldn't be any difference in the watch's functions, so now I'm waiting for their response. I'll share it with you all once I get it.
I listen to all opinions, but sorry, I don't agree with you! You order from here because you trust them and expect to get what you ordered. Of course, I checked the website and email address; there's no error there. However, as mentioned before and as some TDs have informed me, this function should work, but it doesn't... And you suggest I wear it and put it on a watch winder? Should I do that because I bought a watch that doesn't work as it should? Is this serious? I'll wait for his response because I'm glad this forum has confirmed that the function should work, but it doesn't on my watch.I think you're overthinking this a bit.. In my view you have a few options:
- Wear the watch at least once every couple days. It'll keep time & date and you'll only have to advance the time / date 1 hour or day for daylight savings time (twice a year) or date to account for 30 vs 31 days (so date change once every 2 months).
- Put the watch in a winder. Similar to above, you'll only have to change 1 hour / 1 day at most.
- Just adjust the time however you like. The movement is robust enough that it will not break being set backwards, but YMMV as these are reps at the end of the day.
All that said, I hope you got the watch from the real CTime (linked from this forum) and not a CTime imposter. In any case, they may be telling you not to set backwards just in the abundance of caution.
... and now I am guilty of 'overthinking' this![]()
I don't believe you mentioned that it didn't work only that CTime advised you not to.I listen to all opinions, but sorry, I don't agree with you! You order from here because you trust them and expect to get what you ordered. Of course, I checked the website and email address; there's no error there. However, as mentioned before and as some TDs have informed me, this function should work, but it doesn't... And you suggest I wear it and put it on a watch winder? Should I do that because I bought a watch that doesn't work as it should? Is this serious? I'll wait for his response because I'm glad this forum has confirmed that the function should work, but it doesn't on my watch.
I’ve been watching several. No one is best. I never thought I’d be doing this just over setting a watch but it has helped meWell, I watched a video too, but maybe it was the wrong one. There's a video on TrustyTime's website of the GMT Pepsi where they set the date both forward and backward. That's also a CF watch, so there shouldn't be any difference between the watches—every TD gets them from the same place.
I think you're misunderstanding my post friend. I'm not telling you to NOT wear your watch and leave it on a winder. I'm suggesting that when you are not wearing it (e.g. you're wearing other watches) that you can put it in a winder so you dont have to worry about the watch stopping.I listen to all opinions, but sorry, I don't agree with you! You order from here because you trust them and expect to get what you ordered. Of course, I checked the website and email address; there's no error there. However, as mentioned before and as some TDs have informed me, this function should work, but it doesn't... And you suggest I wear it and put it on a watch winder? Should I do that because I bought a watch that doesn't work as it should? Is this serious? I'll wait for his response because I'm glad this forum has confirmed that the function should work, but it doesn't on my watch.
I don't want to try it because if it breaks, they'll say it's because I turned the date backward. It should indeed work, but they wrote not to use it. I mentioned that there are customers who ordered from them, and it should work in the 2nd position because that's what they were told. So the question is, does CF have a new movement, or did they order a different watch for me?I don't believe you mentioned that it didn't work only that CTime advised you not to.
If it truly doesn't work there is an issue but are you sure you are doing it correctly? When in position 2 you have to go back a few hours, it's not going to flip right at 12 like it does going forward, try going back to 8 or 9 and see if it flips backwards.
you dont have to respond if you dont want to. I dont insist. kind of showing your character. lolYou get what you pay. Paying minimum but then asking RWI members to do the service they have to pay premium at TD (confirming to be sold what is advertised) is kind of showing your character.
You are way overthinking this. CTime is just covering themselves. Set it backwards and just enjoy it.I don't want to try it because if it breaks, they'll say it's because I turned the date backward. It should indeed work, but they wrote not to use it. I mentioned that there are customers who ordered from them, and it should work in the 2nd position because that's what they were told. So the question is, does CF have a new movement, or did they order a different watch for me?
Gotchayou dont have to respond if you dont want to. I dont insist. kind of showing your character. lol
I don't think you understand my response. I'm not going to buy a watch winder just so I don't have to set my watch as often, and I don't necessarily wear it once a week—I have about 8 watches. The point of my message is that if I hadn't asked, I would be setting it backward all the time. If it's the 26th now and I need to set it to the 23rd, why would I turn it forward so much, especially if it has this function? If the watch truly can't perform this function, even though many members here say theirs can, then why can't mine? Moreover, if this is the case, it should be communicated before I order. You see, it's all about honesty(and trust), especially in the case of a TD. It's in their name and should be in their service too.I think you're misunderstanding my post friend. I'm not telling you to NOT wear your watch and leave it on a winder. I'm suggesting that when you are not wearing it (e.g. you're wearing other watches) that you can put it in a winder so you dont have to worry about the watch stopping.
But as you've said, you bought it from CTime - plenty of other members have their DD3285s with no issues however they set the watch, so just wear it and enjoy. I think you're worrying too much about this.
Sorry, but what don't you understand? All I asked for was to be informed before I ordered that this function doesn't work. Isn't that fair? That's all I requested. As a Trusted Dealer, this is to be expected. If they don't tell me and I don't ask, then it's sure to break soon. But the real question wasn't about that; it was about someone being told that this function works for this model, but in my watches, it doesn't anymore... I didn't ask for much, just honest communication. You're paying $500-600 into the blind world (you dont know them) because there are a few TDs you trust. Oh, and one more thing—when they sell it to you, they don't tell you it's a Chinese piece of junk that will only work for a few years. I also have replicas that have been working fine for 4 years.It's a replica. It's $500. Set it backward if you want or not. It could break wrong if you sneeze at it wrong. Wear it and enjoy it and if it breaks it breaks. Noone is going to promise you that the replica watch will last 3 years or the underpaid Chinese worker that made it that day did an oopsie. It's $500 made in shitty workshop conditions. Wear it until it breaks then toss it and buy a new one. Otherwise if you want a 100% guarantee buy the $15000 gen
If it has a dd3285 movement it should be ok, just be glad you dont have a Breitling Navitimer Gen! To change the date on those is a real pain! You need to move the hour and minute hand between 2000 hr and 0000 hours and then back until you get the correct date you want, this the reason I have a 4 watch winder box in the safe!.Well, I watched a video too, but maybe it was the wrong one. There's a video on TrustyTime's website of the GMT Pepsi where they set the date both forward and backward. That's also a CF watch, so there shouldn't be any difference between the watches—every TD gets them from the same place.
