Cool stuff. "Carlow" I would keep the steel. The green bezel might just be overkill.
Keep the steel, nice contrast imo.
Switch out the case and second hand for gold.
This we like, having done your reading means you're on a winner already. I'm sure @Karbon74 can get you some he is in EU.Long time listener first time caller. I've spent the past few days reading all 36 pages. I have ordered a White moon phase from W77 and now considering what case to go with or rather whether to go with a blue or black insert. I also need to order my PE50 stems.
The one thing I may have missed is, is there anyone offering the 3d printed case inserts in the UK? I have checked my local library and not something they have available. If not, I am sure I will find a way.
Thank to all posters for sharing their expertise and experiences.
I've also found that adding a chapter ring will prevent it from moving forward.Is this the Pagani?
Three things can happen when building
1. You accidentally lift the dial from the mvt. With a normal 2h subdial this pops out the handwith the moonphase you won’t see it
2. The holder is too small. The dial feet are fragile. When you screw in the crown, the mvt shifts left and displaces the dial.
3. This can also happen when you screw shut the caseback if the holder binds into it
Chapter ring?I've also found that adding a chapter ring will prevent it from moving forward.
It's actually the standard VK63 that most people here tend to use.Is this the Pagani?
Thank you for confirming. I have downloaded the files already but so far haven't found anyone locally with a printer. I can see on eBay that some people offer the service but I had hoped to find a local enthusiast.Ask @Caboose for the print files
Noone is doing UK relay unfortunately and shipping from EU is bloody expensive for the thing
