Karbon74
Pika Factory
11,337
22,926
EU - Kalos Region
Still have some debugging to do
For some reason the small seconds stops when I screw in the crown 🤔
@Caboose any idea about this? Have you even seen this?
@Pinion Minion the 2h hand is frozen with your technique. Man, i knew this movement was cheap…but I had no idea how cheap 😂
The more I think of it, the more I want to slap the ETA in this thing…even if it’s ridiculous as I never use the chrono 😅
Reactions: Sweetrep
dannyboiii
21
13
And finally my aliexpress parts has arrived. It wasnt a brick! The watch was just what I expected but the speedmaster text is smudged out. I will soon to receive the white snoopy as well so Ill compare both. Will most likely swap out the dial as I prefer white.
Ive put them together using the v4w parts(thank you caboose). It was slightly bigger than the actual case so I sandpapered the edges to trim the diameter down by half mm ish. V4c had slight play inside the case so wasnt the right fit for my case.
One thing I wasnt sure was the rotating crown feels grindy. Not sure if its my case? stem? or Ive done something wrong. It all works though.
Interestingly the battery fitted was LR920. I assume sr626 will still fit anyways?
rwi_enjoyer
18/5/24
Which case did you get?
dannyboiii
21
13
So i fully debugged it now*
*almost…the acrylic rep crystal has cracked and has hairlines all over 😂 I will need to replace it eventually but for now I feel it adds to the charm
That is something else! I actually like it. Can you remove specific text on the dial?
Karbon74
Pika Factory
11,337
22,926
EU - Kalos Region
I like the way you think 🤗
I was tempted to erase any reference to Swatch. it’s easy to do and invisible on an aged dial after treatment
But I decided against it as it would create imbalance on the dial layout
gprime
22/12/23
14
12
So I got a good deal on a gen moonswatch and I attempted the metal case mod on it. What a pain in the butt. I thought I could just dremel off the back an the movement/dial would just pop out. But nope, had to destroy absolutely everything. It's sandwiched in there so well.
Way too time consuming, and I was paranoid about destroying the dial every step of the way.
Process wise, I give it a 1/10. Would not recommend. Reps are definitely the way to go!
Reactions: sting and Karbon74
dannyboiii
21
13
there was a gen moonswatch disassembly video on youtube which I cant really find.
But I remember that the easy way is to open from the glass. Once you get your way to pull the stem
it seems to comeout fairly easy
sting
59
56
3 more on the way 👍
Reactions: Karbon74
Karbon74
Pika Factory
11,337
22,926
EU - Kalos Region
That red is nice
It looks like Swatch has seen my Ultraman Concept 😂
and the green black has potential but the hands have to go
I don’t know what to think about the last one 🤔
Reactions: Caboose and sting
Karbon74
Pika Factory
11,337
22,926
EU - Kalos Region
The only gripe I have is that PE50 hands are not very common and you need to mod NH35 hands.
I need to check out VK63 hands too
Reactions: sting
sting
59
56
That red is nice
I like the green and black one, because of the hands 😂
Reactions: Karbon74
sting
59
56
Yeah, this is definitely a pain! I wish they'd just start selling the hands and dials separate, surely there's enough demand 🤔
Karbon74
Pika Factory
11,337
22,926
EU - Kalos Region
Why would they?
This way they sell a package for a higher price. Less logistics, higher revenue, negligible extra cost = higher profit
Also, remember that buyers of mods are a minority. The silent majority just overwhelmingly buys out of the box
Reactions: sting
dannyboiii
21
13
Would be nice, but not for pe50. To be fair its a crappy flimsy movement I woudnt even be interested in if it wasnt for the moobswatches. Its a 3-5dollar movement that goes into budget kids watches
sting
59
56
I did wonder about that, I thought it must have been built specifically for the Moonswatch reps 👍
Reactions: dannyboiii
dannyboiii
21
13
I was wondering… is vk63 movement compatible with moonswatch rep dial? Dial placement seems similar
