DapperDoctorHolmes
- 102
- 72
- 28
Successfully completed the mod with a cheap replica case I nabbed from someone on Reddit as well as with a Pagani Design V6 (making one for a friend and wanted to compare the two). It's not a great replica, so the case is heftier than it should be (comes to 15.6mm including the crystal and replica case back). Compare to the Pagani, which is 14.2mm including crystal and case back. The bezel on the Pagani is also better, both in terms of height and in terms of accuracy. The case backs are also interchangeable, although the replica case back is roughly 0.4mm thicker.
Only downside to the Pagani is the Omega crown I bought off Ali-X didn't actually fit - does anyone here have a link to one that does definitely fit?
The 'Replica' is on the left, Pagani is on the right.
