Late to the party, but this build gave me a lot of problems. Seems like every break went against me.
It started with a set of hands that were defective…the seconds hand is too short. I was going to swap in a Datejust hand, but started to like the idiosyncrasy after a while. Will eventually swap it out, but it is kinda like something you’d find on an older watch.
Then attempted to use a NH movement in a 34mm case, which is not worth the trouble. I’m loving the Seiko movements, but too much custom tweaking required to use them in the smaller case. It working perfectly now, but it was a long, tedious road.
Then it all had to be torn apart and redone, because the hands were rubbing against the crystal, so a custom dial spacer was printed to go along with the custom movement spacer. Lots of trial and error before it finally was right.
Finally, a cheap AliX jubilee bracelet that’s actually very good for the price ($5 USD, what’s not to like?!?) and Gen like to the extent the end link gaps are awful (seriously, though, Gen folded end links are like this on lots of vintage watches). I got a little tired of leather, Oyster, and NATO, so tried something different.
Gen (ref 1500) case set
Clarks t13 crystal
Raffles dial and hands, aged and re lumed
AliX 6mm crown and jubilee bracelet
NH38 with custom dial and movement spacer
