I meant, the gen 6429 case. Does it have 2mm lug holes?which case? the raffles 34mm?
can you confirm on one of your gen case sets ? or do you think they were enlarged specifically for this reference?Looks like it
Rolex COMMANDO Explorer 6429 (SOLD) - The Vintage Concept
Brand: Vintage Rolex Model: 6429 Year: 1968 Serial number: 202xxxx Reference: OT0504thevintageconcept.com
I don't have a gen 6429, but this is a photo and a link to a couple gens...those look like bigger holes for 2mm bars.can you confirm on one of your gen case sets ? or do you think they were enlarged specifically for this reference?
Thanks, I believe it is safe to assume that commando used 2.0mm lug hole.I don't have a gen 6429, but this is a photo and a link to a couple gens...those look like bigger holes for 2mm bars.
All of my gen 34mm cases seem to have 2mm holes, although I haven't measured them. I can do it when I get home, but my assumption is that Rolex Factory wouldn't have 2 different sizes of holes and spring bars.
It kind of makes logical sense that at least the sport/tool models would have more robust spring bars. Not sure if the dress versions would need the extra strength, but those (to my knowledge) also use 2mm bars. You're more likely to lose a watch permanently climbing Mt. Everest or diving a shipwreck than you are if a springbar fails a a cocktail party, lol.
Women's models, in a time when "equality" didn't mean the same thing as today, might have used more delicate bars, I truly have no idea there.
You can use a 2824 in a 34mm gen case, stem height is close enough to work, and I think all the 4 digit, 34mm Rolex cases are essentially the same, with minor differences in case back, bezel, and crystal (and the model number between the lugs, of course).Thanks, I believe it is safe to assume that commando used 2.0mm lug hole.
I also found a gen 6426 mid-case for sale on eBay. The price is a bit too steep for me. But this raises the question of whether the ETA 2801 and the Rolex 1220 have the same stem height?
I'm actually quite positive, the ETA 2801 & 2824 have the same stem height.You can use a 2824 in a 34mm gen case, stem height is close enough to work, and I think all the 4 digit, 34mm Rolex cases are essentially the same, with minor differences in case back, bezel, and crystal (and the model number between the lugs, of course).
I don't think all of the 28XX have the same stem height (I think the 2836 is different, for one), but I think the 2801 is a modified 2824, so it should be drop in with a movement adapter ring.
I don't think the 6426 is anything special in and of itself, but I think they're expensive because people build Franken Commandos out of them. If memory serves, the 6429 was a special run of the 6426 for the Commando model, and there's some belief that some 6426 had Commando dials originally. That said, there's lots of unreliable information on models like this, which weren't terribly desirable (or even known of) until long after their production runs had ended. They're not as well documented as Submariners, Daytonas, or even Explorers.
The 5500 Explorers are similar in many respects, lots of opinions, very little reliable information, other than half remembered third party anecdotes, lol. There's also more "upgrades" that people try to pass off as original...generic 6426 with Commando dials, sold as OEM Commandos, just like there's a lot of 5500 Air Kings redialed and sold as 5500 Explorers.
It makes it a little risky to try for a correct build, but it also makes it a little easier, as there's some wiggle room in what parts to use.
I'd be cautious about paying a premium for one of those 6426 cases...they're missing a case back, and I think the Commandos, being manual wind, used a different case back than the regular 34mm automatic watches. I might be wrong here, though.
I concur I dont think a 2mm bar with 1.3 ends were used on gen 34mm cases
Today, I received the case, dial and hands from raffles.
Within 20min, I managed to ruin a dial (you can see the big scratch at 7) and break a crystal. But well, that's life.
The next step will be drill & tap the case to accept the correct tube and crown. I've never done this before, I hope it will work.
Ah well, there is only one as far as I can see. Which is why I didn't share the link. But if I decide to not buy it, I'll send you the link. Sorry, for the slightly weird approachthat looks good... do they have more?
no problem I dont need one I was just curious if there was a source for 19mm rivet it looks goodAh well, there is only one as far as I can see. Which is why I didn't share the link. But if I decide to not buy it, I'll send you the link. Sorry, for the slightly weird approach
