Do show me the resultsNice work brother that was quick. , Thats good enough for the girls I go with, as they say. Thanks for doing this.
Please keep in mind, gentlemen, Rolex probably (definitely) had a few printing plates that were rotated between watches. Therefore, if the layout is there, the following texts should be easy to find if searching for that text only. I view it as 5 sections.
1) ROLEX
2) Oyster Perpetual
3) Commando
4) SCOC/OCC &
5) T-Swiss<25 or SWISS
1 & 2 are usually found together, and 3 & 4 can often be found together: 5 isn't a dealbreaker.
Just sharing my thoughts in case high resolution photos aren't available. I'd bet a pretty penny that a Submariner or GMT Master +/- 10 years of that has the exact same printing, and those high resolution photos are more likely than not readily available. Trust me, I'm OCD, okay!
Actually, this is a bit better![]()
I also used that bracelet on my 6541/Explorer combo (It's a fantasy watch with Milgauss dial/hands in a explorer case). I was surprised with the bracelet, really not bad for the price!Finally, a cheap AliX jubilee bracelet that’s actually very good for the price ($5 USD, what’s not to like?!?)
af-294I'm currently building a Commando based on a Raffles case. However, I'm having a hard time finding the right plexi for it.
I would like to use a domed plexi, but the ones I have and that I and can find all have the beveled edges (Clarks and a most generic T12s for instance).
What would the the appropriate non-beveled plexi for this build? Any suggestions are more than welcome.
I tried to find them online, but I couldn't find any for sale. A*F crystals are all NOS anyway, so super hard to find the right one. Do you have a link perhaps?af-294
Would the N Sternkreuz 29.4 work as well? It's much more readily available.af-294
As long as the inside diameter fits the lip, the outside you can shape with a dremel and repolishWould the N Sternkreuz 29.4 work as well? It's much more readily available.
Thanks. I indeed used the GS PA 459-37 on one of my 5500 builds with a gen 5500 case (which you recommended in an earlier post). However, the GS PA 459-37 doesn't fit the Raffles case. The inner diameter of the plexi is too small unfortunately.I would like to use a domed plexi, but the ones I have and that I and can find all have the beveled edges (Clarks and a most generic T12s for instance).
For vintage cases that call for 25-12 crystals, I use GS PA 459-37 on Rlx 5500, 1002 etc. They have rounded sidewall tops and are high quality.
They always fit if the case/bezel are oem spec.
The GS PA 459-37A crystals have beveled sidewall tops like modern Rlx acrylic crystals.
That looks like the Yuki dial. ?
Nope dear sir. I did everything myself from preping and modding the dial to the art in MAC and creating the dial myself via decals.![]()
