How to Repair VSF 126610 Submariner Bezel / Hytrel Ring - Long Term!
Slugger
Absent Minded Professor
2,218
1,846
Any idea who in the US could solve this issue and potentially also optimize the bezel play? Thank all for the help
I’m glad you are willing to give someone else a chance to fix it for you.
Explaining how to fix or replace a bezel is a bit like sharing a recipe. I could tell you all the ingredients, cooking temperatures and times but our results would not always be the same.
Truth is, everyone of us who do this regularly, has their own way of doing things and often we use our own custom made or modified tools. Most of the time, it’s a simple job but all of the time, there are a lot of ways to screw things up.
butler182
650
688
Will a YoYo ball bearing lubricant work?
I typically use a very light coating of silicone grease. When things are really tight, I have also used Molykote DX Paste for a little extra lubrication.
butler182
650
688
No sure about YoYo ball bearing lubricant. You have to be careful that whatever lubricant you use is compatible with hytrel...some lubricants can break down hytrel over time. Silicone grease is definitely compatible and I've never had any issues with Molykote DX Paste.
butler182
650
688
I think i have damaged the Hytrel. When I turned the bezel I think it cut of some of the material. But the problem is really that I cannot get it deep enough.
The deeper i pressed it the easier the turning was. Maybe the lubricant really helps. Also apparently I should greese the clickspring and the parts, too.
And I believe I understand why I have that play in the bezel. The Clickspring simply has some play. A new clickspring should fix this.
Even if the hytrel ring is damaged, you can probably get it working fine. Just work out the kinks and give it another go. Also, you could try flipping the hytrel ring...some rings have a little step on the inner perimeter (L shaped) and are orientation specific. If this is the case with your hytrel ring, the correct orientation could make a big difference.
Reactions: Valaj
Valaj
411
505
Illinois
Yes I agree. It sounds like an issue with the hyrtel ring. I had a similar issue. In my case, the hyrtel ring has a small kink and that was what made it get stuck (like you said, it was extremely hard and almost immobile but the bezel popped out very easy compared to when I had to pop it out the first time). I removed and gently tried "re-shaping" the hyrtel ring. When I was reinstalling the bezel, I turned it while gently pushing on it and making sure it didn't get caught anywhere. That worked for me.
Reactions: butler182
Artyfowl
You a college guy or something….?
485
391
UK - London
Does the hyrtel ring sit in the groove just below the ceramic insert or the groove further down the bezel ring? Mine was sitting on the watch case when I removed the bezel so didn’t have the chance to see where it was fitted.
Also I’ve just changed the crystal and pressed the retaining ring right down to the watch case. Is this correct? I hope so.
37,544
80,338
You didn't say which model you are working on. If the insert is press fit there will be another part under it, an insert support ring. The bezel groove is below that.
If the insert is taped in the bezel groove is directly under the insert.
This thread has more pics if you need them
6-digit Sub crystal and bezel swap
The retaining ring should be fully pressed down to the case.
Artyfowl
485
391
UK - London
Hi KJ. It’s a VSF sub no date 126610
Fish line arrives today 😂😂
37,544
80,338
Start small (thin diameter) with fishline and work your way up to thicker diameter to decrease looseness. Don't force the bezel down if there is great resistance. Also I recommend leaving the insert out until the bezel is installed with its final selected fishline in place and it's working well.
Using fishline as a hytrel ring
Artyfowl
485
391
UK - London
Ok so fishing line is the future 😂
Prof crystal installed. I’m happy with that….
One ball bearing spring disappeared to the netherworld and one was bent and wouldn’t sit right to let the bezel click in so I left it out. Running one spring and the click spring and all is good. (I’ve ordered replacements from Ali but to be honest it’s working well as is.
bertieng
1,276
486
Also, I won’t stress how annoying it is forgetting about the Rolex crown etch in the crystal and having to take everything apart again to sort…
computer rage GIF
You have my respect for being adventurous.
BTW, which gauge of fishline did you finally use to give the perfect fit?
Artyfowl
485
391
UK - London
0.7 worked for me. Took some pressing to get it to sit in the bezel groove and not pop out but working well
Reactions: Valaj
Raffaelloczz
Bode miller
391
515
Does the hytrel ring guarantee the waterproofness of the watch or not?
I replaced the hytrel ring of my vsf sub because the bezel was hard in the movement with the ring of a sub ARF that I no longer use, now the bezel rotates well but I have a very small play of half a millimeter because the hytrel ring of the sub ARF is less thick.
I would not want to have compromised the waterproofness.
butler182
650
688
The hytrel ring has no impact on waterproofness. Good fitting and properly seated crown gaskets, caseback gasket and crystal gasket are the mains things to worry about.
Cubatobaco
Horological Specimen
852
1,079
VA
Bought some extra Hytrel rings today , but fishing line needs to be in this house as I am always fixing GMT's (my favorite watch). Today, when taking off a C+F bezel, it brought the crystal / gasket/retaining ring and all. I was like WTF!? After multiple attempts and different retaining rings, I figured I needed a new hytrel ring (too thick / stretched) and some silicone grease on the ring to allow the bezel to turn. As it sits, everything is clicking , moving, and sounding good. Just need a new gasket and, unfortunately, a new Pepsi insert as I cracked it trying to reinstall. Such is life with a GMT!
wristonfire123
160
69
United Kingdom
After reading in an earlier page about someone using dental floss to help 'thicken' the hydrel ring by wrapping it around the ring. I've just found another way by combining it with the electrical tape coating the hydrel ring channel on the bezel.
I've only tried it with the flat dental floss, using silicon grease to keep it in place but it has worked well. First attempt made the bezel too tight, to the point that it couldn't rotate. Not even a little. Great considering that before the whole thing would pop off if you tried to rotate it at all.
Second attempt, I thinned the dental floss by sticking a needle through the middle and pulling it along to give me a piece that was about the width of human hair (from your head 😂) I didn't think it would work as it was so thin, but wanted to start small and work up. Using the same method, grease to hold the floss in place while adding the hydrel ring on top so secure it in place. Snapped the bezel on and it worked. Nice rotation in both directions with the click each time now that some of the grease had been removed. Abiet added to some new locations. (CF GMT) Feels secure too.
I used to have different rolls of fishing line that I'd used before but moved countries so threw it out. Turns out with enough tinkering and forum lurking you can figure it out.
