GMF Explorer II 226570 with VR3285 Made with Gen as Reference
Neo_7
Follow the white rabbit
566
285
Explorer looks and feels way bigger than a 41mm Sub.
Really ?? They seem quite similar… maybe because of the white dial and stainless steel bezel … it can look bigger but in the end it’s not too much bigger than a 41mm Subs..
ronin007
1,237
689
Kent England
Stil got this one,2015 noob version, my old beater ,been through the wars, explorer lettering faded nearly away
mapimages
61
95
Jacksonville, FL
I made the same consideration… and plus with GMF you have the best overall quality feeling .. I mean look at the case ..bracelet ..clasp.. hands set..
This is good to know. Think I will go GMF for overall quality. I have found many gen crowns, but swapping out the GMF crown is a simple process? Or I would assume simple for a watch repair shop no?
Neo_7
566
285
Yes GMF is the way to go... and I believe swapping the crown is somehow easy if you have the right amount of expertise and good tools... :)
Reactions: mapimages
Sarotti68
Daytona lover
21/5/23
91
180
33
Someone posted in this Thread that gen crown does not fit the gmf tube. Maybe a smaller vsf crown will fit the gmf tube. Also the clasp of my GMF is the worst clasp i have on my reps….
Sarotti68
Daytona lover
21/5/23
91
180
33
But, its a great watch and its a rep, so i don’t care if the clasp has minor defects, as nobody will see them when i wear the watch…
Reactions: catana1981
CTbeforeLP
1,156
1,436
Canada
Yeah, the genuine explorer crown doesn't fit the tube on the GMF v5.
They used a smaller diameter tube...
And yes a DJ41 crown does fit... BUT it looks way too small. And looks more off than the bigger crown on the GMF.
I would be curious to see if the gen explorer case tube would fit the GMF.
mapimages
61
95
Jacksonville, FL
Thanks for clarification on the gen crowns…still will probably pull the trigger on the better overall watch and deal with the bigger crown. As always, the photos emphasize what is probably not a big concern anyway.
Submariner23
AddictedRolexManiac
895
2,126
Lume is on both on point in my opinion.
Also no problems with bracelet and clasp….smooth and sexy
….and I don’t give a F💥💥k about the wrong crown size😂
Really great Rep for this small investment🍻cheers
Submariner23
AddictedRolexManiac
895
2,126
Just heard that they don’t produce this reference anymore because of movement problems…and now crown update?
PTVGA
9/10/22
12
N Georgia
Thank you for this.
Other than getting the black dial, I will have both eventually as well.
Question regarding the Lume. I am truly amazed at VSF's lume on the sub. I can always tell the time, from when I first go to bed, until when I get up while still dark, glows like a champ.
How does the Lume on the GMF hold up overnight?
I'm still amazed I decided to get the Explorer II, unsure if I'll like it as much as the Sub.
