GMF Explorer II 226570 with VR3285 Made with Gen as Reference
Burt Macklin
269
175
London
I've had a GMF polar Explorer II now for just over two weeks and I can attest to the movement being absolutely garbage now. Ran absolutely perfectly for the first week but now I have trouble setting it.... once I do the second hand gives up after around a minute and I have to unscrew the crown in order to get it moving again. Sounds like the same issue others are encountering.
Very disappointed in the quality of the movement, I guess I will have to find a replacement GMT movement and a watcmsmith to replace it. Does anyone have any recommendations?
CTbeforeLP
1,370
1,743
Canada
This is the part you need to replace.
dogwood
2,532
5,797
Canada
Super franken explorer II
- GMF case and bracelet
- DD3285 with gen date seat for the Explorer II
- Gen dial
- Gen hands
- Gen case tube + Crown
- Gen Crystal
- Gen Datewheel
- Gen balance complete
- Gen barrel+mainspring
Beautiful build.
Reactions: CTbeforeLP
CTbeforeLP
1,370
1,743
Canada
- Gen dial
- Gen hands
- Gen Crystal
- Gen Datewheel
I swapped over to a C+ Case + bracelet for it's superior rehaut, and brushing finish. But I kept the GMF bezel.
I have tried this in the past with the SH3285 but it never fit as the date seat on the sh3285 has little nubs that go around it that protrude more than it should. Shaving those down a little could probably help if someone wanted to do that.
But since now I have dd3285 with a Gen date seat that doesn't have that issue, I tried again. And it fit in perfectly.
It's also nice to know that the C+ case tube is gen spec and can accept a Gen crown.
Yuvalti
MULTI ACCOUNT
9/7/24
14
If you're into high-quality reps, this might be worth checking out.
tongsui
1,721
1,216
AUS
One of my client's GMF explorer is experiencing some issues and im exploring options for him. Just wondering
@dogwood @CTbeforeLP have you guys experimented if the GMF sh3285 entire date plate/bridge can be migrated to a 126710's dd3285 , to make a hybrid 3285 that will work with the GMF dial.
Any response be much appreciated
Yacht-Monster
The entertainer previously known as Roughwatch
1,187
920
The Eternal Winter
- Gen dial
- Gen hands
- Gen Crystal
- Gen Datewheel
How do the visual parts that you mentioned compare to the gen parts? I know there’s comparison reviews but it’s always different with the naked eye.
Fantastic build BTW.
dogwood
2,532
5,797
Canada
Yup it’s been done. It requires a bit of work. This is the starting post about it. There’s another post later in the thread about finishing the job.
tongsui
1,721
1,216
AUS
Thank you for sharing ! Admire your work :)
