Comprehensive Guide to Clone Movements Found in Rolex Reps
dogwood
2,469
5,531
Canada
I forgot to say but have you seen this weird skeletonized 4130?
It's been used in some replicas, it's claimed to be a 4130 but some parts are 7750... any thoughts @dogwood ?
Interesting. That’s a skeletonized Dandong (Peacock) SL-4801 movement. The SL-4801 is Dandong’s “street legal” copy of the Rolex 4130 movement. And by “street legal” I mean they changed enough about it that Rolex stopped suing them for IP infringement.
Reactions: Reaps
HardyVancity
24/6/23
West Coast Canada
The vs3235 is an excellent movement. If your QC pics showed a healthy amplitude (>250 with lift angle set to 55 degrees), then you probably don’t need to get it serviced right away. But you’ll probably want to get it serviced within a couple of years and then every 5-10 years after that — every 5 years if it’s a daily watch, 10 years if it’s a drawer queen.
Great Post! I find myself in a situation concerning my Super Franken Submariner 16610LN. Built by a reputable watchmaker within this community, features a VR3135 movement. However, it's experiencing a decline in its once-robust amplitude. Given that it's my everyday timepiece, I've entrusted it to @dogwood , relying on his expertise to replace the movement with a DD VS3135 : )
Reactions: Mikie C
Daniel_AUT
68
20
So my DD4130 has an amplitude of 283 and 52.0 degrees on the QC videos, I'm curious ;)
Dctke
3/1/24
13
The gritty feeling when threading on the crown could be from grit in the threads. Remove the crown (press the release in the winding position). Then use a foam (not cotton) swap to clean the threads both on the crown tube and inside the crown. Then apply a little bit of o-ring lubricant to the o-rings in the tube and the one in the crown.
I did this and it’s much better, still a little rough when first starting to thread but then smooth after that. Photo is of what came off on the foam swabs from both the stem and case side. I lubed o ring on stem, crown entry on case and case back.
Reactions: dogwood
dogwood
2,469
5,531
Canada
Nicely done. I’m often shocked by how dirty crown threads are.
Dexxter
70
61
I also had to clean the crown on my clean 126500. After applying some oil it´s possible to unscrew and rescrew it very smooth. Sadly the crown itself is a little sharp edged :(
Any tips on how to make it more smooth?
geoffdragon
Member
605
1,042
Uk
Wet and dry sandpaper - go gently as these crowns can be surprisingly soft metal.
Here is an example for you, after taking the crown guards off this Daytona I smoothed and rounded the crown too.
Reactions: dogwood and Dexxter
Daniel_AUT
68
20
Most people are also worried and immediately do a service/revision that if they get a watch with VS3235, SA4130, DD3285, etc. that the movement is supposedly dirty from the assembly and assembly of the Chinese and the Chinese do not oil these movements properly Far too little, I have no idea whether that's true or not
dogwood
2,469
5,531
Canada
It’s variable. I’ve seen movements from China that were perfectly assembled, clean, and correctly oiled. I’ve seen others which were filthy and over/under oiled. It’s a roll of the dice.
Daniel_AUT
68
20
that is absolutely correct!!!!
Daniel_AUT
68
20
Which would also be interesting, but that's why these clone works haven't been around for that long. There's just a lack of long-term experience here... how long the works last or the material, whether that's comparable to the lifespan of a GEN
Reactions: Trebor88
316lad
975
1,943
How long any movement lasts is really down to a question of metallurgy and machining tolerances. With most of the parts in a movement being interchangeable - particularly with clones - what you're left with is the baseplate and the bridges. If those have been machined from good brass and then nickel coated and milled from well callibrated machinery then the answer is - it should last a very long time. But if there's slopiness in the workshop/ factory then parts interefere with one another and wear unevenly - the Mainspring Barrel being a prime suspect for slowly eating through it's arbor/ spindle holes - but even those can be remedied to a certain extent. Likewise the Keyless Works - if components in there are sub-standard (yoke, Click Spring, etc) it'll find an excuse to take a bite out of itself at some point.
Advise given earlier is a good fit - If it's working - shows good Amplitude/ Winding and time setting feel smooth - leave it for a bit.
But if there are any feelings of grinding/ nasty noises - have the thing to pieces and give a full service.
One of the commonest problems seen with these movements and the ETA clones is de-burring not being done on components and that's a sure fir eway of allowing that component to start eating it's neighbour.
19,760
Many people who have the original NOOB 4130, which if you bought in 2020 is now 4 years old... no issues
Same with the VS3135... 4 years old ish at this point and still chugging on strong
Reactions: 316lad
ndan246
29
This is the movement in my GMT Pepsi. It of course has stopped working and I am looking for a replacement movement. Is the VR3186 compatible with my case? I have read that it is but I need a movement holder?
Can anyone help me with this? What is the best movement to replace the A3186 movement pictured>
Thanks for the help
ndan246
29
Thanks for the help
ndan246
29
2 years maybe. I just took the back off and that is definitely the movement I have though. I want to say it is a GMF but I cant be sure.
