Yes. The hands, dial, and case are a perfect fit.Can a VR3230 be replaced by a VS3235 and then apply the mod you made @dogwood ?
Hi friend!Thanks for the graphic contribution
@dogwood @KJ2020
I have 2 questions:
1- I have CF 3285, VS3235 VS3135, and Gen 3235 (datejust). All Dandong movements have a very loose feeling when moving the crown to adjust the minutes/GMT hands unlike in the gen 3235 where the crown feels more firm and solid when adjusting. Similarly, VS has very loose feeling when adjusting the date wheel in VS3235/13 unlike the firm clicks feeling when adjusting the date in the gen 3235. Is there any way fix to the looseness feel in DD/VS movements and make more like gen feel?
2- Why is it difficult for Dandong factory to clone Rolex’s beat adjustor and balance wheel (with the tiny screws on the rim of the wheel)
Thanks
Can you write a link ?I agree with @dogwood re buying stems on Aliexpress. I have done so many times. My recommendation is buy at least two (or what @dogwood would call “n + 1”. I usually buy several at a time because I hate waiting for a replacement stem to be delivered from China and they aren’t very expensive.
For crowns with a broken stem tip, I have successfully removed them using alum powder in warm water. While I suppose not all rep crowns are created equally, usually the stem tip will ”dissolve” in the solution leaving the crown unaffected. I think there is a youtube tutorial or how to easily found.
I’ve never heard of holding the watch in a certain position when winding it. Thinking about the keyless and winding works of both of those movements, there’s nothing that can move due to gravity, so you could wind the watch on a roller coaster and it would be just fine.My apologies if this has been asked and answered:
Is there a proper way to set and/or wind the DD4130 and/or VS3235 movements? I’ve heard something about only winding a certain amount of times or only changing the date and/or winding when both hands are pointed down to the 6:30 position to increase the longevity of the true clone movements. I’ve also heard to change the date slowly. Are there any special things I need to know?
Yes, to the naked eye the balance is the easy way to tell gen 3135 from vs3135. But under magnification it’s possible to see a difference in the surface finish of the parts.Awesome resource! I commend you for your time & effort. So am I correct in thinking that the only’tell’ between a Gen 3135 and a VS3135 is that the rep will have two levers off the balance and the Gen will only have one? Thanks.
The vs3235 is an excellent movement. If your QC pics showed a healthy amplitude (>250 with lift angle set to 55 degrees), then you probably don’t need to get it serviced right away. But you’ll probably want to get it serviced within a couple of years and then every 5-10 years after that — every 5 years if it’s a daily watch, 10 years if it’s a drawer queen.Fantastic write up. If purchasing a 41mm Sub with the VS3235 movement. Does it still need to be disassembled, cleaned and regreased?
Hi Dogwood,The vs3235 is an excellent movement. If your QC pics showed a healthy amplitude (>250 with lift angle set to 55 degrees), then you probably don’t need to get it serviced right away. But you’ll probably want to get it serviced within a couple of years and then every 5-10 years after that — every 5 years if it’s a daily watch, 10 years if it’s a drawer queen.
There is some debate about what the correct lift angle is for the vs3235. I tend to use 55 degrees when I'm using my time grapher. Although I've seen others use 58 degrees. And you are correct that increasing the lift angle setting on a time grapher will result in a calculated value for amplitude which is higher.Hi Dogwood,
Have been enjoying your post’s immensely! I have a VS on its way and have just received QC, I have made a post in the General forum with regards to amplitude before I saw this post… the timegrapher has been set at 59 degrees which I believe for some reason VS factory say that this is how it should be tested?. Is that just to achieve higher amp values? So at 55 degrees it is sitting at about 256 amplitude… so you think this is acceptable? Hope so as the rest of it looks incredible
The movement in your Daytona is a Dandong 4130. This is an excellent (the best) Daytona movement.Question about the SA4130 on Daytona I recently purchased new. It is a 116509 (replica of white gold with blue dial). Attached are photos of the movement, I took the back off to ensure it was the correct movement. Here’s the issue:
After winding and setting the watch, when screwing down the crown, it changes the time (from time to time, no pun intended). Also as it’s tightening down, I can also feel it wind a little more. The additional winding doesn’t bother me but it’s certainly a pain to set the time and then have to unscrew the crown and redo it. Is this common or is there something that can be done to fix it?
Forgot to mention, it also feels gritty when I’m screwing it down, this is the only 4130 I have but the VS3235 I have screws down very smoothlyQuestion about the SA4130 on Daytona I recently purchased new. It is a 116509 (replica of white gold with blue dial). Attached are photos of the movement, I took the back off to ensure it was the correct movement. Here’s the issue:
The gritty feeling when threading on the crown could be from grit in the threads. Remove the crown (press the release in the winding position). Then use a foam (not cotton) swap to clean the threads both on the crown tube and inside the crown. Then apply a little bit of o-ring lubricant to the o-rings in the tube and the one in the crown.Forgot to mention, it also feels gritty when I’m screwing it down, this is the only 4130 I have but the VS3235 I have screws down very smoothly
