Booonin
334
45
guys is there a consensus yet? AR+F or clean v2? the latest i know i think ar+f better dialbut clean better movement?
JOSswag
152
134
Just wondering, does the gen crystal sit correctly on this watch? Im using 2.3mm gen gasket. Maybe some expert can help me to take a look at these. Thank you
Reactions: AG91
MerovingioRS
104
At the moment which versione is available?! V2 o V2S? I ask to CTime and he said me that v2s version is out of stock! 😔
Milburn1
97
101
33
V2 is good insert. Platinum filling on numbers is very good. Eventho’ tad flaking around triangle, but really unnoticeable in person.
It looks brilliant in these lighting conditions, this is what I wanted to see in normal every day lighting 👍🏻 the bezel is a bit concerning though regarding the flaking. Hopefully it holds up and doesn’t get worse over time.
leo6929
1,751
1,192
Received my V2S yesterday. This watch is on fire!! too many pics updloaded now by other members, so I won't post more. Only quip is that the crystal is a little bit too high.
Will solve it by getting a gen gasket and crystal at some point. After four iterations, I am happy with this one! :)
Reactions: germanynrw
Akilles
Lord Commander
1,331
1,789
The North
95% v2 posted here so v2s would be highly appreciated.
Reactions: Fervid
BlossomboofyBoofystewie2
415
234
Australia
Can you tell me which TD you used? THANKS! ED
mariot
309
209
They made a limited number of V2s and now if someone buys a new watch it will come with v2 bezel?
In the meantime the new bezel on the clean daytona v3 116520 is very bad.
in v1 & v2 it was almost perfect.
I don't understand why they are taking steps backwards when they can make good watches
wubsub
i like subs
2,284
2,995
sorry who are?
my friends gen insert compared to v2s posted by another member. in my opinion, the v2s insert is based on this revision of this gen model as it doesnt turn pastel red.
v2s numbers are muted, thin, dull, blue is not correct and red not so pronounced.
i would stick to the v2 considering the above points and the flaking of the v2s. it's far from good.
Reactions: dk2852 and diamonds
Mark1937
4,338
3,851
You have to use 2.70 gasket with gen crystal. 2.30 gasket it will make the glass too low, and consequently the date will be too small. the closer you bring the glass the smaller the date, the further you move it the bigger the date.
JOSswag
152
134
Bet! Thank you bro. Appreciate it
