CERAMIC INSERT REMOVAL GUIDE.
Audi_5k
25/11/22
Has anyone attempted to use boiling water to expand the bezel and hopefully have an easier time removing/installing the ceramic insert?
36,276
74,248
For a press fit insert, stainless steel isn't going to expand enough to allow the insert to just fall out. And by the time it was cool enough to work on any benefit would be lost. Also there is risk of damage to marker fill.
For a double-sided taped insert, a soapy water soak is a technique to loosen the tape and release an insert. No boiling required.
Itto
Overly Invested Hobbyist.
1,697
3,954
Giulia's Apartment
Yes, actually tried it and like KJ said, it has no effect.
But the method Oascom describes here works very good, just make sure you have the dies prepared / notched out.
Reactions: Audi_5k
RyanEdwards
33
Thanks for this info. I followed today after cracking by insert. Really appreciated.
Reactions: Oascom
unagi
God Luck and Good Speed
400
373
Just finished machining up some press die prototypes for the gmt inserts removal. These are pretty similar to the Rolex ones. See how they go With testing
How did these work out for you? Thinking of making some myself.
Oascom
Brigged
INMATE
4,412
5,076
You welcome.
For everyone i will be selling full kit of specially designed insert dies for removal and installation.
For more.info shoot me a PM
Reactions: Karbon74 and Endo
Oascom
Brigged
INMATE
4,412
5,076
New GMT insert removal die available:
cacti
274
133
Hi all, great thread. Question if any can help me. I just purchased a gen insert + bezel that is already together. Can I just snap the bezel only the watch as is or do I need to remove the insert first?
36,276
74,248
You can press the combined bezel + insert on in one step. You must be extremely careful to not press on the insert though. I'm sure you know how easily they can crack.
Either way you do it now carries some risk. Gen inserts are press fit, which alone is a risk, both in separating the pieces and in joining them together again.
If you press the pieces back as a combo, use a die that contacts the bezel only and not the insert at all. Make sure the bezel goes down evenly all the way around and not lopsided. That can cause the die to slip from the bezel and contact the insert. Plus it makes it harder to seat the bezel.
Be sure to verify that a bezel gasket (hytrel ring) is installed in the bezel groove and inspect its condition for cuts, tears, or hanging slivers. It can be massaged some with a toothpick and tiny amount of silcone grease. This will also aid in a smoother pressing to the case.
Reactions: Karbon74
cacti
274
133
Ooof that sounds complicated. So you can't just put on the full bezel like you can a 4 or 5 digit sub?
Appreciate the response.
36,276
74,248
No it's not simple like earlier models. You should read some more about this process and maybe try removing and reinstalling your rep bezel before attempting it with gen parts. You didn't say what model you have, but the steps are quite similar with any.
6-digit Sub crystal and bezel swap
6-digit GMT bezel install sequence
cacti
274
133
