Bellatorseo
- 35
- 9
- 8
Amazing post! Thank you so much. Is the bezel removal process for the Daytona similar to the subs?
I believe that is called the Horotec MSA 07.115-F: I also have the same tool but naturally it's not original (?) even if it comes with a branded box. Yes, besides the replica watches China is also making replicas of the tools used in Horology from the notorious gangs of Bergeon, Horotec, et all.I use hortec tool with bezel removal attachment
Now I have to find the MSA 07.115-F attachment replica (!) and it seems not an easy task: any help would be welcome...
Cheers
Yes, I know the Chinese tools are usually crappy, but essentially I would just replace the blades with the original ones, if only I can buy them separately! And I only need these tools very sporadically.
Besides I believe the originals are way overpriced anyway...
I'm sorry if somehow I'm now diverting the thread (if you feel we are straying too far, please ignore me): do you use these four blades to remove rotating bezels as well?
Usually you can push on one side of the rotating bezel and using the 'famous' butter knife or something more appropriate on the opposite position you will eventually get the bezel pop out, since these types have some amount of a gap to allow them to rotate that you can exploit...
Fantastic guide !! Thanks for sharing your obvious wealth of knowledge!!!
Sent from my iPhone using RWI
Under some natural light
Clean Factory dial will follow
Time doesn’t exist, clocks exist
Looks amazing mate! I'm glad I could help a little. Yes of course doing it by crystal press / rack is better because you have a even push all around.
I did it by hand to demonstrate and also I did it on a rep bezel and insert and those are easier.
Gen inserts I always press witht rack press as those are much tighter fit in.
Ps.... Did your heart stop when you heard that "click" sound at the end ? Haha
What is the process for removing a ceramic GMT Master bezel insert from an ARF?
Same?
