For cheap tubes you can use a torx bit that grips the inside diameter even with a friction type, I twist out. Not sure if the Pagani is a twist or screw type however.
Can you please attach the link where you bought 6 pack of PE50 spacers? I couldn’t find it on Ali or DH.<img src="https://images.clickpix.org/hsgcsi.jpeg" alt="hsgcsi.jpeg" border="0">
<img src="https://images.clickpix.org/hsgV9X.jpeg" alt="hsgV9X.jpeg" border="0">
Well while waiting for QC on a Tudor I bit and did one too.
Case from:
Watch from:
I grabbed a six pack of PE50 spacers and glad I did, the 32mm fit perfectly.
Only issue is crown doesn’t properly screw down, maybe you can see in the picture. Thinking perhaps the stem is too long so might open her up again if I find the time.
Thanks all for the MANY entertaining pictures and indeed, how tos to get to this, cheers!
Bravo!
It works but not all casesBravo!
Is this a 1701 V6?
What diameter is the crown? 7mm?
I just found this on AliExpress: €21.52 | Watch head accessories for the Omega 7.0mm Adjust time button crown parts tool
This one?
Bravo!
Is this a 1701 V6?
This one?
Careful with the 6mm, it is tallerI think it’s the newest PD 1701 V6, it’s what I intended to order. There are a couple of folks here active on this thread who are very familiar with the various versions and the subtle differences, they can probably inform us from my picture what version I‘m showing to be sure.
And don’t order that 7mm! I usually use 6.5 for my generic case builds but even that will hit the crown guards of this 1701. I ordered a couple 6mm once I realized this, that’s what you see on mine.
I’ll have to come back and edit this post with the Ali link.
What do you mean taller? Like sticking out more?Careful with the 6mm, it is taller
The crown is taller from base to top, yesWhat do you mean taller? Like sticking out more?
I wasn't going to grind down the 6.5mm crown or grind on the case
Thanks for the linkAs usual Karbon is correct!I discovered that but did not think to detail it. I didn't see much of an option for this Pagani build as I wasn't going to grind down the 6.5mm crown or grind on the case.
See pictures:
Should be link to Rojozor store:
AliX 6mm Omega crown
sorry, the 6.5mm crown?Looks good.
Who supplies the 'Logo' crown?
