DapperDoctorHolmes
102
72
13.7mm would be a dream! That’s wild that the new rep caseback shaves off an additional 0.2mm over the Pagani’s stock case back since it already looks so flat - guess I’ll have to ask Jason for some of the newer casebacks.
How much were they?
Reactions: pippo
M Scott
Daytona Aficionado
22/9/18
866
1,190
How much were they?
$25 USD each for the Replica Casebacks.
Yeah the 13.7 is my favorite, also without the newer blueish Pagani AR coating.
pippo
3,882
397
How much were they?
I believe we might place a group purchase given the common interest
Caboose
1,813
2,664
I think if we did a group buy we'd do full cases with bracelets. I could handle US side shipment and also include the 3d printed movement holders at no extra cost. Could also include a single PE50 stem for a small fee as well. Would pretty much be a build kit at that point!
Tippyracer
I am Spartacus
115
133
FL USA
There is a lot to like about the Pagani 1701 case:
But I would like to seek advice from you fine (and not-so-fine) gents who already have done the Pagani case mod-
What did you do about the crown? The standard AliX crown that works on the standard AliX cases does not fit to this tube.
Reactions: pippo
Karbon74
Pika Factory
11,299
22,823
EU - Kalos Region
Pop the tube off and put a crown with the right tube
It should be 2.5mm in
I never keep the stock tube. It is slightly longer than the rep crown tube so the crown never sits flush if you don’t change the tube
Reactions: DapperDoctorHolmes
Tippyracer
I am Spartacus
115
133
FL USA
*SIGH*
I have been avoiding even thinking about that since I started this terrible hobby. And having a hard time justifying the $40 on a crown tube press from Ali.
Generally how hard are they to push out? Maybe I can jig something up and ruin a perfectly good case.
Karbon74
Pika Factory
11,299
22,823
EU - Kalos Region
If you are confident and accept losing the pagani tube, then just yank the tube out with pincer pliers
Another option is to use a 2.3 mm stake to push it out with a hammer
But you need balls 😅
Pairs Rotum GIF
Reactions: Tippyracer
