roflwaffle
160
42
I think the 1862’s case was actually a mold of a moonswatch, but I might be wrong. The 1861 is the same size as the 1862, but their factory missed a finishing step and never chiseled the angle designs into the midcase, so they just appear chonky even though they’re technically the same size.
It's not correct, and not 1:1 with moonswatch or moonwatch
Just an improvement over the 1861.
I havnt even been able to get confirmation if crystal is attached to bezel like Ali/Jason cases or pops off like gen/Pagani. Watchdives wouldn't answer. Don't think crystal size is genlike either
Reactions: DapperDoctorHolmes
roflwaffle
160
42
But you're right they're same size and it's just a profile thing. Though the v1 also had a silly Rolex style caseback and other differences (wonky or missing crown guards or something and other odd choices)
DapperDoctorHolmes
102
72
Ooh that looks great Karbon - which case and how’d you age the lume?
I’ve been looking everywhere for some Alpha shaped hands to fit these a la the FOIS style hands, but I keep coming up empty.
Reactions: Karbon74
DapperDoctorHolmes
102
72
Initial thoughts on the Watchdives 1860 vs. Pagani 1701:
1. I can't actually build the Watchdives yet, as the case requires a 34mm movement holder (the 33mm is too small) and the 34mm ones are currently out of stock on AliX 😅
2. Thickness: The WD1860 is 13.9mm thick vs. Pagani's 14.2mm (The Pagani is 14.5mm with the replica caseback - I haven't tried swapping it to the WD yet, but on side profile the casebacks look the same, whereas the original Pagani caseback was considerably more flat)
3. Bezel: The WD1860's bezel is the most 'accurate', and it sure is pretty. It's Aluminum rather than Ceramic, and includes the 'Dot-Over-90,' as well as the quirky unmarked 450 dot (i.e. there's a dot above 400 and below 400 on the bezel). The text is Aluminum on Black, AND the font is accurate.
The Pagani Design's bezel is Ceramic, so it has reflections, it does not have the 'Dot-Over-90' or the quirky 450 dot, and the font is fatter / wider. The text is pure White on Black though, so it is more contrasty / slightly easier to read. The entire bezel insert itself also appears to be slightly thicker than the Watchdives.
4. Crystal: There was a ton of chatter about the crystal on the WD1860 being worse than the WD1862; I haven't held an WD1862, so I couldn't tell you how it differs beyond spec (the WD1862 used a Bubble Sapphire, the WD1860 uses a Domed Sapphire) but this one seems perfectly fine. Maybe's a little thicker than the PD1701's? They look pretty similar to me. The AR seems a bit better on the WD than the PD, and it doesn't have any discoloration - so if you don't like the blue hue that takes over the Pagani crystal, this is a good solution to that as well.
5. Pushers: The pushers are definitely heftier on the Watchdives than the Pagani - it feels like a switch on the WD, more like a button on the PD. I.e. the WD kinda clicks, and the Pagani pushes softly. That might currently be due to the VK63 movement inside the WD vs. the MoonSwatch's PE50 in the Pagani, so I'll check that again later too. The pushers on the WD also sit slightly lower in the case than the PD; the PD pushers top out slightly above the midcase angle, whereas the WD pushers top out slightly below the midcase angle. This is probably the one place where the Pagani wins in terms of closer to gen, as the pushers on a real Speedmaster (and on the MoonSwatches) seem to usually top out above the midcase angle rather than below. They do appear to sit a little low on the WD1860.
6. Case Shape: I think the bezel height is the same between the two, which means the WD is likely saving 0.3mm on the midcase. The WD is roughly 11.6mm without the crystal, vs. the PD's 11.9mm. Again, the Watchdives looks closer to 'gen'. It's more angular than the Pagani, which slopes less and is more gentle in the curve, and does appear have an ever so slightly thicker midcase. It's really hard to tell in person though, they don't visually stand out that much in terms of thicknesses.
7. Lug-to-Lug: I'm measuring these from the side of the bracelets on each so they differ a bit from advertised, but the Pagani Design is 47.9mm, whereas the Watchdives is 46.6mm, which is the same as my rep MoonSwatches.
Still dreaming about a true metal version of the MoonSwatch case (13mm thickness, really beautiful and balanced angles and portions between bezel and midcase and caseback), but the WD ain't bad.
8. Crown: The Watchdives Crown is noticeably larger than the Omega rep I put on the Pagani (can't find the OG Pagani one to measure against, but I did have to size down to get it to fit the crownguards on the Pagani case). The Watchdives is 6.4mm, vs. the Omega rep on the Pagani's 5.8mm.
9. Rehaut: Hard to tell and hard to measure, but it looks like the dial sits a little deeper in the case on the WD than on the PD. That's in pretty stark contrast to the WD1862, which folks have said barely has any rehaut and where the dial seems to jump out of the case. I'll reevaluate this when I'm able to actually swap a MoonSwatch dial into the case, and in any case they're both miles ahead of the gigantic 15.6mm VK63 blank cases on AlIX with huge rehauts that cause the dial to look sunken.
Side notes: The Watchdives bracelet looks better than the Pagani but both are pretty awful, especially when compared even to the rep Omega bracelet. This mostly comes down to the deployment clasp more than anything else, which is uncomfortably shaped and only opens in one direction rather than two, so it's not actually large enough to pass your hand through and then close down enough.
pippo
3,882
397
@DapperDoctorHolmes
thank you so much for the detailed comparisons.
Overall, given the rehaut and deep black insert, I would probably take the Pagani.
I was tempted by the bracelet too, seems a better fit for smaller wrists (no visible gap between the end link and the first link).
Is it so bad?
Thank you!
DapperDoctorHolmes
102
72
@DapperDoctorHolmes
Is it so bad?
Thank you!
Personally I prefer the WD insert and the rehaut didn’t seem that noticeable, but I’ll do a more in-depth comparison when I get a 34mm spacer and can really compare the two 1-1. That might be a while though since they’re out of stock on Ali (plus shipping time whenever they are back in stock)
I’ve also got smaller wrists, and the Pagani bracelet flat out wouldn’t go small enough for me - sized all the way down, it was still too large.
The WD fits down to size, but I actually kept it slightly larger because the deployment clasp is so useless - it only opens in one direction (and folds larger than the actual clasp) so it doesn’t open large enough to actually fit your hand through when sized down.
I’m out for the day but will take some photos tomorrow of the two bracelets next to each other for quality / texture / color comparison.
Note that both the PD and WD have female endlinks (as does a regular Omega) so on a smaller wrist the bracelet drops straight down from the lug (if the lug-to-lug width already covers your whole wrist) whereas the rep Omega bracelet that I have has male endlinks, so it still curves out but does make the watch wear a bit longer since it sort of expands the visual footprint beyond the lug to lug width.
Reactions: pippo
DapperDoctorHolmes
102
72
I can also try to do a magnification test on the two crystals with some paper and the empty cases; it’s possible the rehaut is exactly the same and one crystal just magnifies the dial differently than the other.
I’ll also note I was tilting the watches completely to try to gauge rehaut height - it’s really not that noticeable when you’re looking straight down as normal :)
AleosMadPa
62
Just did a test fit today as Ive got almost all parts here. I didnt actually build it since the pushers of the Pagani case arent long enough to engage with the movement.
If I recall correctly you guys used shrink tube for that?
Also my Mission to the Moon from dhgate seller qq409906347 had a silver ring (kind of like a miniature rehaut/chapter ring) on top of it. Do you guys trasfer it to the metal case or does it work better without?
Reactions: Karbon74
Karbon74
Pika Factory
11,309
22,858
EU - Kalos Region
Just get rid of it
Reactions: AleosMadPa
DapperDoctorHolmes
102
72
You can use a 32mm spacer and a 1mm steel wire that you wedge around it in the case
Don’t think I have any 1mm steel wire lying around unfortunately, but will keep that in mind!
It’s interesting that some Pagani cases seem to require a pusher extension and some don’t - mine worked perfectly fine without it, but it’s possible the plastic movement holder I’m using fills in the space between which other movement holders might not?
Karbon74
Pika Factory
11,309
22,858
EU - Kalos Region
After some time you know just by looking if the pushers will make it or not.
The spacer has nothing to do with it. Did you see that from the exact same Pagani model?
DapperDoctorHolmes
102
72
Interesting! I don’t have that vintage looking all steel bezel model, but I’ve had a few PD1701s and none of em had any issue reaching the pushers ¯\_(ツ)_/¯
I mistakenly thought those movement holders had a plastic tab that went over the button / went between the movement and the pusher to shorten the distance, but nope it’s just a gap. I guess some of the cases differ? Maybe QC isn’t the same across the board?
