DapperDoctorHolmes
102
72
Price is slowly going up and the black insert version is out of stock.
The slim case is VERY tempting!
Ooh good catch; I hadn’t pulled the trigger yet either.
There are other shops offering the same, including this one, which, is a bit more money, but also offers a red bezel option:
I just found this on AliExpress: $34.02 | 40mm VK63 Case Silver Watch Case Stainless Steel Watch Strap Aluminum Bezel Fit VK63 Quartz Movement Watch Accessories
Karbon74
Pika Factory
11,315
22,867
EU - Kalos Region
I think @pippo was refering to the watchdive homage
Karbon74
Pika Factory
11,315
22,867
EU - Kalos Region
🤮 WARNING 🤮
I got this PM…
This is peak laziness in abusive ask…
(Anonymized and translated for sharing)
I am contacting you because I saw that you are French and that you have made a custom steel mod of the Moonswatch yourself. This is a project that interests me a lot, and I would like to try my hand at it too.
However, from what I have read about your experience, it seems to be a bit more complex than it seems. Do you think you could provide me with a detailed guide on how to proceed, as well as a list of all the necessary materials?
I thank you very much for your help and the time you will take to answer me.
Caboose
1,813
2,666
🤮 WARNING 🤮
I got this PM…
Anyone who reaches out about metal moonswatches, I provide them two resources:
  1. This thread
  2. Some french guy who is closer to them than I am (usually)
Hprelude
3/10/24
13
Or pick up some of these and then trim to size if you don’t mind waiting:
I just found this on AliExpress: $1.68 | Dial Foot Watch Universal Dial Pin Diameter 0.6mm Copper Material Fixed Dial With Locating Pin Repair Dial Watch Repair Parts
But if the pre-existing dial foot snapped off inside the movement, you’re probably not getting it out again so glue or tape might be easier.
this looks interesting! Might get some for other builds as a just in case thing! It I think I’ll just double sided tape this dial to the movement
What will happen is that the dial will shift and touch the subdial pinions, and that will fuck up the movement
The only true solution is to remove the hands then glue the dial using epoxy or double side tape
Thinking back, I removed the movement holder before removing the stem which was difficult. I think that’s when I broke the tabs off the dial! Might order another blue rep.
DapperDoctorHolmes
102
72
I was just trying another dial and case switch (Mars into Black Snoopy) when the back cover of the Mars case stuck to the movement and caused it to lift out at an angle, snapping the stem inside in the process - so these things do remain frustratingly fickle. Particularly since the way the PE50 is constructed means the stem tends to snap at a juncture that’s entirely inside of the movement, and entirely non-retrievable. If anyone has any tips for removing a snapped stem rather than junking the movement and doing a full dial swap to a new one, I’m all ears.
At $15/pop these days I think I might just buy enough of them to keep the switches switched rather than moving them back and forth 😅
Sampling of the aforementioned switches:
M Scott
Daytona Aficionado
22/9/18
866
1,190
Unfortunately, the quality of these Chinese MoonSwatches seems to be getting worse and worse. Especially the color and print quality of White Dials.
- Might have to just start using real ones as donors... :unsure:
Reactions: Caboose
Caboose
1,813
2,666
The Laupo ones are pretty fine, but watches_77 is gone unfortunately!
davelister
441
525
What's the best way to lengthen the pushers a little to reach the contacts properly? On my black watch the chrono will not start, but the snoopy is fine.
pippo
3,882
397
on Aliexpress someone says the Moonswatch dial has a too narrow diameter
It's in the comment section
NEITON 40mm Dome Glass Silver Blue Black Square Watch Case Stainless Steel Fit VK63 Quartz Movement
"Good quality case. Unfortunately unsuitable for a moonswatch metal mod though as the diameter of the rehaut is too large. Would suit a a dial ca. 32.8 mm in diameter."
Reactions: kidcreole
M Scott
Daytona Aficionado
22/9/18
866
1,190
The Laupo ones are pretty fine....
Thanks, I'll give them a try.
I tried a couple on Alie, Really fast shipping, and I got a great Lava that even has the rings in the Sub-dials.
But the Mars and White MoonPhase were all junk.
Even if you found a good seller on Alie, they get shut down in a short time, and then come back under a different store name.
Karbon74
Pika Factory
11,315
22,867
EU - Kalos Region
Heatshrink tube 1mm inside diameter (after shrink)
2mm length
Put on pusher pin
Heatgun (careful of your fingers🔥)
Trim to good length, the extension has to just touch the contacts
Reactions: davelister
DapperDoctorHolmes
102
72
I've had good results with qq13751589026 on DHGate, that's where almost all of mine have been from.
I did see that review of the Corgeut case, but I suspect that customer might've been confused - for one thing that listing is actually direct from the Corgeut store (so that seems to confirm it's the same case) and some folks here have done that swap with the full Corgeut Speedmaster without issue, and for another it seems they were confusing rehaut (the vertical height / depth from dial to crystal) and the overall size of the case. Based on their measurement of 32.8mm I'm guessing they couldn't get it to sit properly because they needed one of those standard 33mm PE50 to VK63 movement holders, but I took one for the team and ordered one so we'll see how it looks when it arrives🤞
Reactions: pippo
pippo
3,882
397
What you say makes perfect sense, the only concern is related to the inconsistency of the production batches.
Hprelude
3/10/24
13
Would you have any photos of the DHgate sellers Neptune and Mercury?
DapperDoctorHolmes
102
72
I haven’t seen / gotten their Mercury, but they’ve been good about sending QCs when asked!
Their Neptune casing is just as incorrect as everyone else’s unfortunately, I’ve not found any vendors that come remotely close to gen, and I looked hard. It’s even more frustrating since they all seem to get the case color right for the Super Blue Moon, and it should be the same case!
This was their QC for the Neptune:
