Looks nice. But it seems you did not go for the case swap with the Pagani Design PD-1779?
I personally Like it a lot!
That’s the light reflectionThanks for the answer!
Interessting - in your pictures, the case looks more silver-ish then black. I remember the case quite dark. But it could be the pictures.
Congrats, you beat me to it - I still waiting for the pagani to arrive
Link to purchase, please! I want that dial
Look very nice indeed!
A v4 case should be fine for your needs. v2 is fine as well. It can be trimmed to fit most cases if it does not perfectly fit initially. I only have custom variants of the v4 because I like perfect prints for my watches. Saves me time when building 10 at a time!Been lurking on this thread of while so decided imma give it go. Got to moonswatch reps ordered, 2 speedy cases and some stems also. Need to find a place to print the holders @Caboose provided files for. The for sale thread i found in M2M was under archive so didnt think i could order from there. Do i need the v2 or v4 holder? One case is from dhgate.(link from this thread i think.)(other is a pagani from alix)
Is there an STL for v4c? Can't seem to see it on thingiverse. Seems like the snoopy caseback is too tight so need more narrow diameter for the case back end.V4 is going to fit most stuff and should be good. You can also always trim V4 to become a V4c or a V4b, which is nice!
- V1 - Original design, unchamfered edges which sometimes caught when closed the caseback
- V2 - Chamfered edges, different logos for different regions (flags, etc.)
- V4 - Chamfered edges, widened holes near pushes to accommodate more cases
- V4c - Same as above but narrower diameter for different casebacks
- V4b - Same as V4, but single diameter instead of double diameter for some cases
I've uploaded the V4c and V4b models here:Is there an STL for v4c? Can't seem to see it on thingiverse. Seems like the snoopy caseback is too tight so need more narrow diameter for the case back end.
where did this dial come from? Doesn't look like any of the moonswatches I recognize!
Thanks!I've uploaded the V4c and V4b models here:
Moonswatch PE50 Modified Movement Ring by Caboose
Movement holder to fit the following case: https://www.aliexpress.us/item/3256804707033900.htmlhttps://www.aliexpress.us/item/3256804920413543.htmlV1 - Original design, unchamfered edges which sometimes caught when closed the casebackV2 - Chamfered edges, different logos for different regions...www.thingiverse.com
from the same popular DH Gate supplier?Just came across a batch of nightmare moonswatch reps.
One has the dial loose, on the other, the reset is super wierd
no another one. I wanted to test it. Stupid idea.from the same popular DH Gate supplier?
