Karbon74
Pika Factory
10,901
21,796
EU - Kalos Region
I was even looking at options to paint the cases...but I gave up.
Every article I saw was saying that paint would never survive watch wearing
Snooky
866
2,480
Somehow I’ve managed to bork the vk63 movement that was inside my Moonwatch rep from the gate. I made sure the crown was in the correct position before removing, but now it’s not ticking when the crown is screwed back in and winds weirdly when the stem is pulled out.
Guessing I’ve facked the keyless works… tried getting to it but it’s nigh on impossible on this vk63. Off to AliExpress I go to get a replacement movement 🤭
Karbon74
Pika Factory
10,901
21,796
EU - Kalos Region
stupid question, are you sure you are using the right stem ? 😅
Reactions: Snooky
Got20Mate
6,918
10,408
Bork is quite possibly the best word I've heard in ages. Will be added to my vocabulary, thank you 😂
Reactions: Karbon74 and Snooky
Snooky
866
2,480
Haha yep I’m sure, but thanks for checking. Basically it was the full metal jacket Moonwatch rep from the Gate I have (with the proper caseback and bracelet etc).
Took it apart to put the ‘Moonswatch’ movement in and do the metal mod, but then a few days ago my friend wanted to borrow the ‘Moonwatch’ rep to try it out. So, I done the swap back again and bam, no longer winding (well no longer winding properly).
Long story short, it didn’t give my friend confidence in the Gate 🤭
Reactions: Karbon74
Snooky
866
2,480
what do you mean "winding"?
It's a quartz 😳
Anyway, at least the Moonswatch movement works then.
Soz, long day. By winding I meant setting the time. I was imagining doing the ‘winding’ movement when posting earlier and then my fingers followed when replying lol
Caboose
1,745
2,559
Wait, you said VK63... do you mean PE50? There is not a VK63 movement in the moonswatch. Unless you did a swap.
Keep in mind if the crown is not locked to the stem, you will have issues with setting the time. Double check the crown is not just spinning.
Reactions: Snooky
Karbon74
Pika Factory
10,901
21,796
EU - Kalos Region
the dhgate speedmaster rep has a vk63. that's what he is referring to
Reactions: Caboose and Snooky
Snooky
866
2,480
Thanks @Karbon74 for clarifying. You’re right, I should have said speedmaster rep instead of complicating things with Moonwatch and Moonswatch, I need some sleep :sleep:.
@Caboose here’s a pic of the b@stard. Now that you’ve mentioned it, the stem isn’t locking when I put it back in and just falls out. So I wonder if I went too hard when pressing the stem release and it’s now simply not locking back in place? It’s pretty impossible to get to the keyless (I watched a video on YouTube and it’s way beyond my comfort zone), so I think this is hard lesson for me to be more gentle!
Karbon74
Pika Factory
10,901
21,796
EU - Kalos Region
Dead for dead, you can try an old trick I used when I dabbled in electronics.
use a pressure air dust blower spray can and just blow on the hole and on the sides under the plate.
Russian method
note : don't do this on a mechanical watch 😅
Reactions: Hesekiel and Snooky
Caboose
1,745
2,559
Really excited about my new builds! The cases are yet another variation so I have literally redesigned my movement holder just for these 10 to fit. There are now five different types of casebacks I've encountered, some different among the same seller. No idea what's going on there!
Karbon74
Pika Factory
10,901
21,796
EU - Kalos Region
try the curved ones.
They are a bit hard to fit, but very nice and soft
Reactions: Caboose
Caboose
1,745
2,559
I'll look into these for next run maybe. Many people really liked these straps so I keep reordering! Very soft and quick release!
Reactions: Karbon74
Kup1712
761
669
What do I need to press for stem removal. I worked just with nh34-36 and pt5000. Noob with quartz movement.
Thanks for help!
