Again about Hytrel ring
antonygr
159
45
Im search table with parameters ring for rolex watch. These parameters are not the same as on AliExpress. I'm talking about rolex submariner 116610.
On ali ring size 31.9*0.7*0.3. from table size 31.9*0.65.065. where is right?
36,276
74,251
The table should be correct
36,276
74,251
A piece of fishline long enough to make a bezel gasket costs less than a penny.
Using fishline as a hytrel ring
Reactions: Tompa
36,276
74,251
Thick and height. What parameters have rolex?
Follow the link I posted for advice on choosing a fishline size. Rep bezel grooves vary in height and depth plus a hytrel ring is a different shape than round so sizes are not really interchangeable.
Reactions: antonygr
antonygr
159
45
I read your guide. everything goes to the fact that the size should be 0.65 as original ring
antonygr
159
45
I ordered a ring on Alibaba, material hytrel with Rolex parameters. I wonder what to get out of this.
36,276
74,251
Can you post a link? Sometimes the aftermarket gaskets work on some reps, other times not. Also please report back if it works, others may benefit.
36,276
74,251
Im buy 10 vsf 116610. Only 2 or 3 have hard moving bezel
Sometimes that can be corrected by flipping the hytrel upside down. There is a correct vertical orientation which can be mistaken at the time of factory install.
antonygr
159
45
I periodically receive 10-20 hours of vsf Submariner 40mm. and they all have bezel paly. It seems to me that there are some problems in the production of VSF or those who produce rings for them. The very first copies that I have do not have such problems. How can this information be conveyed to vsf?
antonygr
159
45
Maybe this is a wear problem of the mechanism that produces these rings? Over time, everything wears out. and requires replacement.
