New 6542 - budget factory option by TS-Station
HAMMER DOWN
241
115
Do all Pan Ams from Li have the same pilot number engraving or is it random? It has 002-59 in the pics.
32,784
59,027
HAMMER DOWN
241
115
Thanks friends!
What's the bet option to contact Ruby? i don't have the login to access the site. That folded link jube is pretty much exactly what I'm looking for.
I will probably try to order the 6542 from Li this week. I just am having trouble deciding which one I want more. I love the understated look of the coke bezel black dial as well. I think I'll end up with both.
muiramas
Erect Aristocrat
18/1/17
5,730
7,102
Thanks friends!
The Coke bezel is actually a Pepsi bezel. Its a very dark blue, which is more noticeable on the albino.
For Ruby, just drop them an email asking for a log-in - prices are on request for most things they have.
I'm undecided on the rivet or jubilee bracelet.
I have a dial from Ruby incoming, and also a replacement plexi because I messed mine up.
Reactions: HAMMER DOWN
HAMMER DOWN
241
115
Thanks for the info! I heard back from Li, Im gonna pull the trigger on a black dial. The serpico dial is what is now available.
BobAustin100
Looking Around
17/3/20
Just saw this.. not an expert but it looks good for the price
I bought the $300 TS Watch 6542 replica recently. If you simply want a knock-around, fine. And service is quick and courteous (they take credit cars too!). BUT it won't fool anyone, even from three feet away. The case is all wrong: Recessed crown (ugh) and poor finish. Even the back is poorly shaped, and the knurling is TOO LARGE for a standard Rolex wrench. The "bakelite" bezel has a rippled, uneven surface, and the colors are too light. And you cannot remove the bezel without essentially sawing it off the case. The dial isn't bad--but it WON'T fit the vastly better Vietnam case. Even the crown is too bulbous. About all I could salvage was the movement , hands, bracelet (not bad), and spring-loaded collapsible stem for insert into the Vietnam Case, using the crown, crystal, bezel assembly, and spacer ring that came with it for $850--hardly worth three US C-notes. STRONGLY SUGGEST that you contact Tom ([email protected]) and start with his SUPERB case and dial--then have him work with his watchmaker to build you a really good replica. He also sells a very nice rivet band (I put genuine Rolex ends on the TS Watch bracelet that came with their $300 6542 replica).
Reactions: RiffRalf
HAMMER DOWN
241
115
Got my QC from Li, the watch looks good overall. It has the S&L dial. The date isn't perfectly aligned in the window, it's a bit biased towards the bottom of the window, but I still accepted it since the lume looked really nicely applied on the dial.
I'm thinking that I can rotate the dial a little to get the date alignment just right.
Really, it's not a big deal, and after wearing it for a while I might just forget about it and leave it as is.
I can't wait to get it!
Reactions: Hor-Fan
HAMMER DOWN
241
115
Mine should be on it's way soon. I'm told that customs there is cracking down on medical supplies leaving the country and lots of checks on outgoing packages are being performed so it may take a little longer.
nikoel
1,056
263
Hey guys. Embarrassingly noob question - I’m not ashamed though;
What spring bars do the gen 6542 have? (Girth, not length)
Do people use a different size spring bars for leather straps? Do people use metal tubes inside their leather straps to reinforce the leather?
djulink
4/9/14
89
71
Hi all,
nikoel, I use the same 2mm bars I'm using with the 6538 (Sputim sold them for a time and I'm using the same with my leather strap).
I'm wondering, would anyone have tips about modding the insert (I reallly like how Redheart and Ishmael 's look like) ?
Cheers
muiramas
Erect Aristocrat
18/1/17
5,730
7,102
Hi all,
nikoelI'm wondering, would anyone have tips about modding the insert (I reallly like how Redheart and Ishmael 's look like) ?
Cheers
Pop the insert out.
Get some 600-800 grit wet and dry and smooth the edges off.
(find a reference you like on the internet - some are very flat, some are rounded)
Be careful about removing material from the edges - inside and outside or you could be left with a gap.
When you are happy with the shape, then you can give it a polish - I used Turtle Wax and a Dremel felt.
Then you can use the same wet and dry to remove the paint from the reverse.
(obviously use a block to keep it all straight)
Find a red and a blue you are happy with - again - find a reference you like.
I favour using model paint rather than artists acrylic as you can do with 1 coat.
let it dry properly and you're golden.
nikoel I got these.
https://www.ebay.co.uk/i/292291863653?var=591191540770
Reactions: KJ2020
RW5513
201
103
This Tom email address did not work.
HAMMER DOWN
241
115
Has anyone tried using generic/ GS crystals on ofrei? There are 3 or 4 different options for #116, different heights, dome radius , flat top, chamfered edge, &c. They also have different dimensions for case/ ring fit., I just don't know how much of an interference fit is needed to work for this particular application
Reactions: Quincy59
nikoel
1,056
263
Pop the insert out.
nikoel I got these.
Thicc & Phat!
Thank you gents
