Vsf / xf sea dweller now comes with vs3235 !
Vi-Lo
637
555
I assume as always there is the possibility for „downgrades“ coming up in such an update - so i should wait for the first reviews before i decide if i pull the trigger on XF A2824 or on the updated VSF VS3235?!
Plenitude
1,546
854
Someone can tell me the clasp code on ARF V4 or so? Thanks
Plenitude
1,546
854
That one looks specific to the SD43 - 4RL - ARF - SEL engraved C4R 97220
Thanks, in fact a friend of mine in China proposed me an SD43 which a friend of his says assembles with ARF pieces, but with 3235 movement. I enclose photos, surely someone more experienced than me will be able to verify. if it is true, between this, the xf I had and the vsf that has now arrived, I would count on putting together the best SD43 possible.
Plenitude
1,546
854
they are two different watches, which one are you referring to?
Vi-Lo
637
555
This one
Plenitude
1,546
854
I don’t care. I need to know if that one has arf case. If yes i will build the best sd43 replica ever.
Repmaster1337
TC, WM9 interested❤️
DO NOT TRADE WITH ME
2,646
1,804
Have 1 omw.
Just need to replace crystal for correct mag or the gasket? Guess first batch is old XF crystals. :(
Thank you.
Wstn33
99
30
United States
Se-Dweller has been on my list for a while now... Both the VSF & XF look extremely good, but the VSF is a slight notch above most notably the SEL's as already noted. 3235 clone takes it.
Reactions: Repmaster1337
StrangwaysAtoll
55
13
Jamaica
Is the VSF only at select TDs? Also, would the bezel springs on the XF/VSF or ARF be interchangeable with genuine to avoid rusting issues brought up earlier?
Vi-Lo
637
555
Sead has it and Puretime is going to have it also… Trustytime also… but you would‘ve to ask the TDs if it’s in stock before you order.
Sometimes a TD can source it for you on request even if it’s not on the website as example
Reactions: StrangwaysAtoll
vincentvegaxx
19
Hello folks, need Your help with one specific detail. I have just received QCs for SD43 XF. Id like to know what u think about "30" marker on the bezel insert. It seems offset to the left. One of my other watches had a similar issue and for this very reason I have never worn it, it was really annoying.\
Reactions: Jooc10
