Vsf / xf sea dweller now comes with vs3235 !
Plenitude
1,464
782
I’m sure you’re going to deny this, but I will remind you how easily these crack when being removed improperly.
In any case, I'm pretty sure it was my watchmaker who cracked the insert, it certainly wasn't seawater. But if he doesn't tell me anything in bad faith ..... I checked some previous photos though, and some cracks were already there. At this point I hope he won't crack the ones I sent him as I specifically asked him to use bezel arf and insert vsf. You who talked about improper ways can you tell me which would be the best method, or is it just manual skills?
Duckber
1,585
869
Is the crystal better/clearer on the new VSF version compared to the XF?
merkon
44
Between the XF and the VSF which one would you go for?
I am new in the rep game and want my first Rolex SD, considering either the XF or the VSF but can't decide
I was ready to go for the VSF until I saw that the VSF version seems to over magnify the date window and now I feel I am back to the drawing board again
Any thoughts?
Vi-Lo
626
551
@merkon maybe read a few pages before…
The VSF is mainly the XF with updated Dial (correct serif) and clone movement!
It really depends on what is important for yourself… I got the XF and I’m absolutely happy with it. What bothers me the most, is the missing serif :D if you see my posts there are some wristies of the XF
merkon
44
Just read through the thread again and again (and again) to try and decide on my next buy.
I am even more confused now!
I wouldn't consider the ARF previously, but for some reason, now I do!
It might be the fact that it seems like a better watch in overall? SELs are better? Clasp and bracelet is superior to the XF and the VSF?
I am literally so confused now...
Would honestly like to hear your thoughts - the fact that the 2824 movement broke down in two occasions also puts me off
Vi-Lo
626
551
yes I can feel it well - often the confusion appears after getting more information :D
You could also get an ARF bracelet separately as example…
merkon
44
But again, the cyclops on the VSF does over magnify and it is very obvious, so the issue will still be there even if you put the ARF bracelet, unless you swap the crystal to a gen one.
What downsides the ARF has on the other hand?
Vi-Lo
626
551
listed up here:
After a long time spent observing the vsf with 20x lenses, the Chinese assembly with arf pieces and several video review of the original one, I came to the decision of which pieces to use to have a better one, with at least one compromise, also because for now it's all theoretical, but the watches are already at my watchmaker's.
Crystal gen.
VS movement
ARF case and bracelet ( but VSF rehaut is better)
VSF caseback (hope can fit cause the engraved of other one is horrible).
VSF dial and hands
VSF insert
ARF bezel
VSF crown
Hazing
And So It Begins... Again
9/5/19
5,188
4,474
I ordered this a few days ago and I am looking forward to QC pics and finally getting it in hand. The pics look really good.
maplesirup
264
75
Europe
This is the job.
ARF Case, bracelet, bezel
VSF movement, dial, hands
Aftermarket insert
GEN crystal.
VSF insert (clean) was broken and not find supply.
Awesome build man.
The gen xtal makes such a great difference. Can't wait to get mine installed on my ARF, altogether with a GEN ETA.
wear it in good health!
Reactions: Plenitude
Seadwellermike
Proud RWI Supporter
This is the job.
Aftermarket insert
GEN crystal.
I agree, but I actually like the VSF lug taper more than the ARF V4 taper.
Gen crown is needed too. And I feel like the ARF dial is the better dial, but can’t use it on the VSF without hurting it.
grafixen
18/6/18
This is the job.
Aftermarket insert
GEN crystal.
Does this mean that it's just a standard swap of the vs3235 movement into the arf case? No mods needed?
