Get2thechopper
- 129
- 113
- 43
Mines Incoming Should Land Tomorrow Fingers Crossed,
Will post clasp code when received. I’ve had to wait a while so I’m assuming it will be new batch clasp.
Worth having. Just remember to use it on the sharp edges only - it will remove your brushing if you use it on the brushed parts!
Which part of this tool did you use for softening sharp edges? You wrote that you did it couple of hours watching movies so can you advice how to do it properly please?
That looks worse than mine, I think we need more members who have got the newer (?) clasp code to post more pics so that we can be certain that it is indeed a better improved clasp.
Did you get this from from a TD? I had to RL two of these from one specific TD (I won’t
mention by name) due to the clasp.
But this one I have GL’d with a new TD...
hello,
is it me or the pip pearl is not centered?
So looking at the 3 sets of QC pics in the recents posts, we have 2 sets of 1LQ and 1 set of H7Z.
To me it seems like a variation; 1LQ may not be the better one.
BobMartian has 1LQ but with a wider gap above the coronet than below it (exactly like my H7Z)
TimeTable has 1LQ that has more even gaps above and below
Fatarms has H7Z that also looks good
Maybe it's something that we can adjust? But seriously on the wrist, it doesn't bother me.
I'll be damned if I can see any tangible difference between the 1LQ and H7Z clasps, outside the normal rep variation.
What about the rest of the bracelet?
