dragon07
85
I am stuck between the two versions for VSF. I will buy LV VS3135. Secondly, I could not decide whether I should buy LN VS3135 or 126XXX new version VS3235. Can VSF make a better update for the new version in the future?
YellowFin
Not pretty, hardly popular
28/1/20
2,527
2,812
Molvania
my LV just arrived, will upload some pictures later, inital thoughts, the clasp is bad and i mean i prefer the noob daytona clasp over it, the 42mm YM had a better clasp also the dw for some reason is very bold at some digits, does a 3235 or 3135 gen dw fit ?
If you prefer a Noob clasp, it must be horrible. ;)
Sidhu6355
324
280
I don't know if he got a bad QC, bad luck I guess, my clasp is solid with no play, datewheel is good too, so, maybe this guy was unlucky, however, it could also be that since this clasp is bigger and chunkier, he might not have liked it initially, just my two cents
stufuse
3,659
2,457
You’re asking the wrong people
Qatar974
236
202
Qatar
Here are some pictures guys, I'm comparing this watch quality to the YM 42 and tge only downsides of this watch is the DW and the gap in the clasp, the gap on the clasp is driving me crazy, but overall the watch is very nice but really needs a v2.
johnlogan
10,144
15,945
Your 5 looks great but your 16 & 19 looks terrible. You might be able to tighten up the clap with a new springbar
Reactions: stufuse
Comebackbaby
36
22
Did you get this from from a TD? I had to RL two of these from one specific TD (I won’t
mention by name) due to the clasp.
But this one I have GL’d with a new TD...
Reactions: Doglover
Qatar974
236
202
Qatar
the problem from top part of the clasp ( with the coronet) it is not straight. i don't think this clpart can be adjusted.
johnlogan
10,144
15,945
I’m not a movement guy but yes I believe a GEN DW will fit. That would look awesome on you piece.
Noob used to make claps like that, with the GAP, changing the spring bar might help as I did the mod myself in the past.
Reactions: stufuse
Qatar974
236
202
Qatar
Will give it a try , thanks !
Qatar974
236
202
Qatar
It is very nice finish on all bridges, wheels as predicted same quality as vr
Didn’t try all gen parts as don’t have any reason to do that but as you see gen balance and bridge fits with no issues
Gen auto module straight fit as well
Gen date disc don’t fit as they made date indicator seating to fit 3135 date disc
You can replace the indicator to gen but then date window in rep dial won’t line up with gen date disc- only slightly but still no go
Then you need gen dial and it may not fit into rep case (I don’t know, don’t have gen dial)
Gen hands fit as they wheels are same post diameter
Testing for power reserve now and is on 50h so far
Please could you confirm that a 3135 dw will fit the vs3235 ?
