WinnerWell I’m stating my opinion having seen VS, CF, and Gen side by side.
If that isn’t candid enough for you, take care cupcake.
Sent from my SM-G998B using Tapatalk
Insults, very matureWell I’m stating my opinion having seen VS, CF, and Gen side by side.
Unfortunately the case shape is very off you would need CF case but then again put a gen crystal on CF as rest is better on CF anyway.
Its' one of those things again once you see it it can't be unseen.
They trimmed it too much looks too straight, slim and not rounded.
Do you mean that the shape of the midcase is off? Do you have any visual depiction to share?
The case shape is not very off - remember Kalev is the original ZZF fanboy.
When viewed orthographically, the case to bezel shape/alignment of the VSF is fractionally off - by less than 1 bezel scallop.
The CF is marginally better in this respect, however, the CF crown guard shape is considerably worse which is a bigger issue IMO.
This pic shows Gen, VSF and CF - note the case and CG outlines.
I'd still take the VSF any and every day over the CF.
Remember literally no one, ever will see your watch like this - not even you, unless you are some kind of pervert, or ballin on instagram.
AFAIK, there is no difference at all.
iPhone Tapatalk
these hands are very gen like
I'm sure the hands on my post raid are much better than the pre raid I replaced it with.. were VSF hands ever this good before? They are certainly much better then the hands in my (early) 116's which were a bit flat and rough edged but these hands are very gen like (this is a post raid VSF126 arrived 2 weeks ago).
Great comparision, well done.
While the VSF lug may cover one less scallop, is the shape of the VSF lug is closer to gen? The CF lug is a little too fat? (marked below).
Hi to all.
I Have received My VSF.
I have One question if Is possIble.
It Is normal for vsf to have First and last Number of rehaut disallined. There are also a version of VSF correcty allined?
thanks ti all.
Hi Folks.
Just in case it helps someone else - I had a bezel that had some vertical play in it. I put up with it for a while but then over time it got worse until I was able to remove the bezel with my fingers, which obviously isn't right. After posting on here a replacement hytrel ring was suggested. I ordered one of these BEZEL GASKET FOR ROLEX SUBMARINER 116610, 116613 AND OTHERS | eBay - I've just swapped it over and it is a perfect fit and I now have a (correctly) stiffer bezel action with no play at all. Really was not expecting it to work that well.
Also, if you do remove the bezel for god's sake be careful you don't lose any of the spring loaded balls at each corner! Take it apart inside a plastic bag...
Hi Folks.
