ForecastMax
756
439
Hey all, got my 126610 in & it looks like the previous owner stripped all the bracelet screws to shit. Can anyone tell me where to source additional screws for the 126610 bracelet?
Many thanks in advance!!
35,928
72,521
35,928
72,521
Good call. Would be nice to know specifically which thread/diameter works for the 126610 but every shape & size fits the bill too; unless none of them fit….
You would have to take one of yours out and meassure it precisely to get one close to the right size. Some rep link screws are not the exact size as any gen-spec one, but I've never failed to make a replacement one work, even if it wasn't exactly like the rep one. These screws are fairly easily sanded, both in length and in diameter. If the diameter needs shaving, you can put one end in a pin vise, clamp it to a bench then sand it with a thin strip of sandpaper, like a shoeshine cloth. Then swap ends in the vise and match up the other end. Screw heads can be polished with 7000 grit then Cape Cod, or brushed as needed.
Fisherman1980
DO NOT TRADE WITH ME
703
219
Just curious what’s the latest SN used for the vsf 126610. The older stocks were 2R2
Fisherman1980
703
219
Thanks for the clarification. Confusing the numbers with the 116 models of 2s19/20
_Unknown
15/2/19
Since this post is getting long, I would like to ask to those more well informed than me if there is anything I should worry with this VSF 126610?
https://imgur.com/a/qLW15DQ
To my untrained eye it seems good to me, maybe the DW a little bolder? Is the "Official certified" dial text correct?
Also the timegrapher... I think 260º amplitude is a good result. What you think about the test?
I read somewhere here the correct lift angle for the test is 55º and not 56º...
I'm far from an expert so any insights from you are appreciated. Thank you!
Tobel
5,494
3,730
Please read the rules, you can't post your QC pics and just ask people to QC your watch
Reactions: Ylijumala
daytona6263
26
Moldova
Hi guys, does anyone know if VS3235 fit in VSF3135 watch? I mean just swap the mechanism, using hand set of 3135 and date wheel, thanks
elconquistador
3,129
458
Same here. 2R6
Post some pictures. Either you were baited and switched (the JVS is still an excellent rep) or some former VSF employee is frankening parts and selling them as full on VSFs.
Sent from my Pixel 6 using Tapatalk
Reactions: boisvert
