Panerai Advice
shoes
393
The tubes are to stop a tight leather or rubber strap unscrewing the screw bar so do provide some purpose but I don't always use them myself
Sent from my iPhone using RWI
mysterio
9,793
867
Sometimes just tightening them will prove to be enough to keep the lug bars in place. Some put weak threadlocker. I mostly just don't wear the watch long enough to fully unscrew them I guess. YMMV. :)
Robb
787
Anyone purchased Mario Paci straps for their Pans if so did they but it from TC Staps ?
Sent from the RWI App
Zulu44gmt
441
44
This should give you a good idea
Robb
787
Being new to the whole
Pam world thing.
Im just guessing,
spring bars are used so that I can change any strap I want onto the same watch
If so! What tool is required to screw them in & out ?
Zulu44gmt
441
44
Pam world thing.
Im just guessing,
Ok - pams require tubes and threaded screws pins. And requires a flat screwdriver ~1.6mm in size to remove any time you want to change straps.
What I posted is a replacement of the tube and screw system. It's a simple push spring bar that is sized to fit in pams perfectly- the ends are sized small/large to replicate the two lug hole sizes threaded/screw head. They are quickly removed with a pin . I bet there's a YouTube on how they work.
Most straps you buy won't come with tubes so you'll have to buy tubes for every strap or you can just buy sets of spring bars.
I
Robb
787
What do you pam experts recommend for the Buckle
Sewn in for security
or spring bar ?
Zulu44gmt
441
44
or spring bar ?
Polished - sewn in if you can. There is also screw type like the lugs - mine always seem to back out even with nail polish on the threads. I go polished because brushed always seem to have sharp edges that cut into my wrist. I have some spring type as well- some times you just get what fits best.
Also if you want some good quality straps - I have three from crown and buckle that fit well.
SuperLory
Well-Known Repist
22/10/15
8,505
5,118
I politely disagree with everything @Zulu44gmt has suggested :) ehehe to each his own
I hate those springbars and nothing I hate most than sewn-in buckles
i repeat, different strokes for different folks
mysterio
9,793
867
I have not tried springbar lugs yet surprisingly even though though they would make my strap changes so much easier. :lol: I prefer my buckles to match the finish of the case as much as possible so they should be screw in. Not that I totally hate sewn in. Sometimes you have to get one or two for that vintage look. ;)
T3RM1N4T0R
The Terminator Mod
15,406
4,258
I have not tried springbar lugs yet surprisingly even though though they would make my strap changes so much easier. [emoji38] I prefer my buckles to match the finish of the case as much as possible so they should be screw in. Not that I totally hate sewn in. Sometimes you have to get one or two for that vintage look. ;)
The spring bar screw lookalikes from panatime are pure awesome. They are even different sized on each end crown side screw head end is larger for the larger hole on the side. Screw thread side is smaller and if you try to install the the opposite way they will not work. Every single pam I get i buy them.
sent from my franken Samsung v6 edge plus
mysterio
9,793
867
I did read that. There was a seller here locally who was a distributor for Panatime, but he never got back to me on my inquiry so I never got to buy them. :( Maybe the ones on ebay are half-passable?
Zulu44gmt
441
44
The ones on eBay sold by WSO fit the same as the panatime. Different sized ends and one end looks like it uses a screwdriver. UK cousins sells them too- was debating buying the 100 pk...
mysterio
9,793
867
Springbars that use a screwdriver? Maybe it's the faux end which looks like it's a normal screwbar.
Zulu44gmt
441
44
No worries mate- not everyone here has to wear a suit with 3 inch elastic cuffs for 12 hours per day [emoji79]
kilowattore
14,158
6,864
My concern on springbars has been their length. They've been too short in my experience so the faux-screw end was recessed inside the lug hole. This might not be an issue to many, but imho it detracts from the gen-like appearance, plus screwing and unscrewing the standard lugbars makes me feel like taking care of my watch :)
