Comprehensive Guide to Clone Movements Found in Rolex Reps
dogwood
2,538
5,816
Canada
Is there any difference in quality between the VS3135 AND VS3235 movement?
thanks
Both are excellent movements. But they aren’t really comparable since they go in different watches. The vs3135 goes in the 40mm submariner. And the vs3235 goes in the 41mm submariner and the 36 and 41mm datejust.
That said, I happen to think the vs3235 is one of the best clone movements I’ve ever worked on. It’s a joy to service.
Reactions: beneton
DVILL
7/7/23
melbourne
thank you dogwood - appreciate the response.
Bolduc Zogmar
98
64
Very impressing work, thank you so much dogwood !
I just got a VSF114060 (M2M), with a VS3130, which is running real fast, like at least 30s+ a day. How can I regulate it ? I'm a complete noob with this kind of stuff. Should I push (vey lightly) the green arrow arm (regulator) towards the red arrow arm (beat adjustor) to lose time, or the contrary ?
Thank you for your help.
dogwood
2,538
5,816
Canada
It’s very hard to regulate a watch without a timegrapher to show you the real time results from the changes you make to the regulator arm (green arrow). A cheap time grapher isn’t very expensive, and there are time grapher USB microphones you can get for your computer (~$40 on AliExpress). I’ve found that smartphone timegrapher apps aren’t very good.
But yes… if you have steady hands and a time grapher, then you should be able to regulate the watch.
Bolduc Zogmar
98
64
Thank you for your answer. I'll see what I can do with a microphone and an app (if I can find one for Mac).
Just to be sure : to slow down the watch I must push the regulator towards the beat regulator, right ?
dogwood
2,538
5,816
Canada
Yes, regulator towards beat adjustor will slow the rate. But it’s extremely sensitive.
Bolduc Zogmar
98
64
Thank you. I will proceed very lightly, but it's gaining at least 30" a day, maybe close to 1mn. I'll wear it for a while, then do precise measuring. We'll see.
NdBnkr
24
14
The Milky Way
I agree with everyone here, what a wonderful guide.
I would like just a little clarification on VS3235 vs VR3235 and VR3230
If I just wanted rock solid reliability and durability and didn’t care if it was more “Gen like” would the VR3235 or VR3230 be the better choice for a 12 series Sub?
dogwood
2,538
5,816
Canada
I’d suggest the vs3235 since it has a shock setting for the escape wheel whereas the vr3235 and vr3230 don’t have a shock setting for the escape wheel. The shock jewel setting will make the movement slightly more immune to damage from knocks.
Reactions: DVILL
aHero
Watch Bro
4,448
6,585
I’ve been staring at this but just don’t have the trained eyes. Is this SH or VR? I think it’s VR?
dogwood
2,538
5,816
Canada
Yup it’s a VR v1… easy way to tell: Black dot on the beat adjustor, screw on the end of the beat adjustor (not the side). That’s a nice movement.
Reactions: aHero
aHero
Watch Bro
4,448
6,585
Slowly learning. Thanks for the confirmation!!
Buythedip
285
204
Here and there, but more there
Legendary post!
It’s interesting to see that some newer releases are more expensive but with worse movements on some TD websites.
I am sure there are adjustments to other areas of these new releases, but in many cases I suspect you are paying a premium for a new release, when in reality you are not necessarily getting a better, more reliable watch.
Reactions: dogwood
raytron
165
37
This post is amazing and super interesting to read. Thanks for the effort in summarizing all that.
Reactions: dogwood
daytonadude
2,321
2,754
I’ve been seeing some confusion around VR vs SH, as if these factories are actually one and the same? This is recently relevant to the new series of VR3131 listed as the movement on GMF v2 Milgauss watches or the new VR3255 for DayDates. Before, at least for a Milgauss with a clone movement, it was listed as an A3131, further adding to the confusion.
Ideally I would buy a VS3135, remove the date position, and swap it for one of these clones, but I’m not sure if the anti-magnetic second caseback might complicate that.
