Comprehensive Guide to Clone Movements Found in Rolex Reps
Levko
Just looking
3/10/23
Is the automatic barrel bridge of the sh4131 interchangeable with the one from the 4130?
dogwood
2,529
5,758
Canada
At this point I haven’t seen anybody who has performed this swap. It’s possible since the known differences of the SH4130/4131 from the gen are in the escapement — escape wheel, pallet fork, and balance. The automatic works on the 413x sits on top of the chronograph bridge and barrel bridge. So it’s possible that the changes in the escapement are isolated enough that they won’t affect the fit of a gen automatic bridge. But as I mentioned in the main article, the dd4131 is probably a better starting movement for any franken 12-series Daytona build.
Service
I'm New. Unknown to this website.
2/9/24
57
39
Thanks for this thread Dogwood. It's been excellent in assisting me with which factories I should select for my Rolex replicas.
Reactions: dogwood
Cubatobaco
Horological Specimen
735
926
VA
I just acquired a Clean GMT II case with a (basically brand new) jubilee band. This will be my first attempt at a build. I am looking at a DD3285 from Aliexpress, but is there anywhere else I should look? Also, can gen parts be easily swapped on this movement (bridges and things)?
I'l be needing a crown/stem, bezel with all the rings, insert, etc, and a dial. Any help would be appreciated. Sorry if tis isn't the right place to ask.
Reactions: juancarlospapito
xZeroCoolx
230
350
US
You aren't getting a DD3285 from Aliexpress or anywhere else for that matter. They very infrequently come up for sale and are difficult to get and you will pay for it.
Most likely cheaper to just buy the watch 😅
Cubatobaco
735
926
VA
Thanks for the heads up...and for laughing.
GellyCool4
18/5/23
I believe the latest version of the SH3285 has the same arms (beat and regulator) on the bridge that we used to differentiate between it and the DD3285. The guide might be due for an update.
This is probably true for the DD/SH3235 as well.
Also, what are your latest thoughts on the DD4131? I’m eager to see it disassembled.
What "guide" is everyone talking about in this thread? I am a little new here and still trying to get accustomed to this platform / design.
dogwood
2,529
5,758
Canada
See the first post in this thread. You’ll know it when you see it.
SS72
3,013
10,391
Australia
The gritty feeling when threading on the crown could be from grit in the threads. Remove the crown (press the release in the winding position). Then use a foam (not cotton) swap to clean the threads both on the crown tube and inside the crown. Then apply a little bit of o-ring lubricant to the o-rings in the tube and the one in the crown.
Did this yesterday with my Clean 124060. It was very rough, gritty, and the crown wouldn't even do that obvious spring/pop out when unscrewed to the winding position. The crown spring was so full of crap . . .
Removed it from the movement (VR3230 and had it in the time setting position prior to removal), thoroughly cleaned both threads with waxed dental floss, put a tiny dab of o-ring lube on the tube thread and gaskets, and popped the stem back in.
Lovely and smooth, and no resistance whatsoever. This is by far one of the easiest, best DIY improvements.
Thank you.
Cubatobaco
735
926
VA
Thank you.
I have found just removing the stem and reinserting, does a lot. My Daytona moves flawlessly, as well as my GMT. Need to purchase some blue grease, but so far so good.
SS72
3,013
10,391
Australia
Not with mine. Should've taken a photo of all the crap compacted in the threads, especially down near the crown o-ring.
Glad your solution was easy. I'll try it first with my next one.
That_London_Bloke
For the record a mechanical issue has been reported on a GMT2 Clean Factory DD3285 movement. Seems the rotor has fallen off during shipping. See below.
Update: I've opened the case, and this piece isn't fix, it fell and that's what is causing the sound moving inside....
x
That_London_Bloke
Hopefully an isolated incident with the DD3285. I hope so cos I've got two DD3285 from Clean Factory (a Pepsi & a Bat Girl) & they are both working perfectly so far. Fingers crossed 😬
dogwood
2,529
5,758
Canada
It looks like a failure of the flange on the triangular socket fastener. I’ve seen that a couple of times on various clone movements eg vs3235 and vr3235. I suspect it’s from somebody over tightening the fastener during assembly and over stressing the flange. It’s an easy fix if you can find a replacement fastener.
Reactions: That_London_Bloke
MrRedBuller
22
Yes that’s my watch, the screw broke during shipment. Right now getting a new screw and taking the watch to a watch smith since the top part of the screw is stuck inside the movement. Nothing too serious but definitely a pity to receive the watch like this.
