If you go with a sub, get a V7 from Noob. You can get it from any TD here.
A2836 or SA3135? Your call. The only people who'll EVER notice the difference in the CG difference between the 2836 & 3135 are the watch nerds here. Nobody else will EVER know.
The 2836 is a work horse. Any watch guy can repair it, parts are interchangeable between gen eta & rep. Or, replace with a genuine eta if you so choose. My point is, there are infinite options.
The SA3135 gets mixed reviews at best. The case is more accurate. It'll accept a gen movement or a yuki 3135 that you can buy from [MENTION=110978]Tickleshoes[/MENTION] . If the SA3135 breaks, you're screwed. The only option is to franken it as mentioned above.
Sent from a remote corner of the world using a series of clicks, grunts and generous amounts of profanity
This is why you stick with the 2836. I'm always concerned if the movement breaks the cost of fixing it would be frightening. I would consider frankening it but that also means big money.
