Ceramic submariner dial guide
didjital7
567
406
He's talking about the hour markers... the white gold cups that are filled with lume - triangle one at 12. He means the white gold border around the lume.
CsViking
MULTI ACCOUNT
28/11/21
132
23
Yes its true you are right the dial with the m with space from number 300 i mean there 1000ft = 300m the dial with 300m is with thick .... and the older dial with 300 m .... space between 300 and m has think around the lume
Alemipd
5/2/22
Hi guys, I am quite new: I have red a lot of post and I am a bit confused. Someone can confirm that today the best replica of the Starbucks submariner 41 mm is JVS ( better than Clean then) ? And I noted that is available only to yhe TD Amf. Someone can confirm please if my understanding is correct ? Thank you (review will follow). Kind regards
UKReps
71
17
I like this tread, well done. Very informative as to which dial relates to which year!
Powerfluff
67
32
Thank you so much, Smoke, for all the hard work you put into this thread.
engbanna1
Gens are replicas of first prototypes
29/5/23
234
151
KSA
Ok so we start with the 116610ln dials first
this is a very very rare dial the og bp dial replicated this
This dial =symbol is not centred with the word date to the right of the x in rolex
This dial has = symbol centred and the word date starting under the x in rolex
This dial is tottally different and is what the noob v2 v3 V4 and v5 tried to replicate it has a flat s in swiss made
This dial has the =symbol centred but the word date to the right of the x in rolex
This dial has a different font for the crown to all the dials.the word date starts under the x in rolex. And the = symbol is not centred
The Last ln dial is like the noob dials but as you can see has skinny marker surrounds also has flat s in swiss made
Here is aNother dial new in 2016 it is simular to the usual long ft dial but with a new font .tall 0 instead of oval .here are a couple more pics of the new ln dial without me marking it
Next is the 116610lv hulk dials
This dial mk1 was not released other than the proto
This dial the = symbol is centred
2016 hulk new layout
And the second hulk dial the = symbol is not centred that's the lv dials
Next the smurf dials
This is very rare and the first dial produced.bp replicated this dial has flat s in swiss made
The next dial the = is not centred and the word date is too the right of the x in rolex
This dial the only difference is the = symbol is centred
This is a brand new 2016 smurf dial layout
Next up are the two tt blusey sub dials
This has thick marker surrounds and centred = symbol
With date to the right of the x in rolex
New long ft blusey dial for 2016
This dial has thin marker surrounds.
= symbol is centred with the word date starting under the x in rolex
Next up is the 114060 there are 3 variety
This has thick marker surrounds and = symbol not centred very rare
This dial has = symbol centred and thin marker surrounds
This dial has thick marker surrounds and centred = symbol
Here is a brand new 114060 dial that will only be on a 2016/17 rehaut case to be period correct.this has thick white gold marker surrounds,bold submariner font.italic staggered = symbol and the same long ft font from the new 201617 6 didget date subs.the only difference is it's a no date.and says oyster perpetual
I've noticed that some dials have a bevel on the date window cut out. It's mostly on Hulks here is a pic
Can’t see the pictures, how can I fix it?
