Caboose
2,393
3,448
can you post a pic of the spring shape please?
Here's the spring and potential replacement which is a aluminum ring that sits between the dial and the crystal in the plastic case. I have relocated to the caseback in the metal build.
Reactions: Karbon74
Karbon74
Pika Factory
12,390
26,230
EU - Kalos Region
Maybe you should put it in a metal case?
woah. how original 😍
Tim And Eric Omg GIF
Caboose
2,393
3,448
Also, has anyone dropped a gen ETA Caliber G10.212 in one of these? Looking to get info on hand size for the purposes of correctly functioning sub dials.
Reactions: Beartooth
Karbon74
Pika Factory
12,390
26,230
EU - Kalos Region
cousinsUK lists
M .90 Hr 1.50 Sec .25 Sub .20
there is a thread on this somewhere
Seems that there are variants of this movement with diff functions of the subdials
The right model is the one that equips Swatch Irony Chrono watches
yokoyoko
Hilfloser
18/12/23
14
24
Hi, i received the movement holder, thx a Lot! But something seems Of with me case?
I use this one:
With the Movement holder i have a Like 1mm „air“ to each side. As this is the First Watch project Of mine - i have no Clue if this is supposed to be? Before i used the original holder and some 3m tape which fitted snugger.
Can you guys help me pls?
Reactions: Karbon74
Karbon74
Pika Factory
12,390
26,230
EU - Kalos Region
I use this one:
look into the plastic rep case near the crystal.
there is a plastic ring
put it in the metal caseback.
screw the crown, put the caseback. Done.
don't forget the gasket of the caseback
Mind you, with these cheap cases, the bezel can be misaligned. It happened to me. I had to take out the bezel and align it.
Also, don't play with the crown too much. the case is not great. It might strip the thread.
about the case, there are a lot of makers, the internals can be a bit different.
