Caboose
1,752
2,570
let's do that then. I am happy to act as your EU agent if there are enough takers later on.
Sounds good. Let's get a list going of people in the EU, and the quantity they want. For the US, I can handle on my end with USPS and will just post in M2M. Once we get a good amount in the EU I will package and you can distribute.
Caboose
1,752
2,570
And here's the glamour shot pictured with an SDU-30 Distress Marker and a Luna Replicas band.
Caboose
1,752
2,570
Ill take a few- what a great little treat!
Here's the M2M.
Caboose
1,752
2,570
One more thing to note... I added to the back of the case a nice little wire spring usually used to attach bezels. It came with the case but I didn't notice it till now and I went ahead and installed it. For sure decent at keeping the movement from binding on the caseback so when you rotate the caseback you don't snap the crown or anything crazy!
DesertAdventures
347
62
Caboose
1,752
2,570
I gotta try some of his. I grabbed a few true shutters off alix but they ended up being like $9 each after Black Friday coupons and discounts. Anyone know of a dsotm cheapo clone that would take the moon movement? That would look nice.
If the $9 shitters work with my movement holder, let me know. If not, would be happy to pick one up for $9 and give us some options!
DesertAdventures
347
62
they were $24 before all the discounts but work fine. This is using Your holder, just trimmed up a little because my printer isn’t very calibrated. the case was such a poor color, posted the pic next to my gen mars for laughs.
Caboose
1,752
2,570
Glad to hear about the movement holder. I may need to add a chamfer to the bottom as your printer could have an elephant footing issues. That would be good for a V2 and I will make those changes! If it isn't the bottom that had issues, let me know!
DesertAdventures
347
62
It was the bottom but it wouldn’t matter. I just haven’t put any work into really tuning settings, I print “good enough“ then give things a quick cleanup 😂 I make tons of little parts on an 8 yr old printer and have to scale prints to get them to line up with the dimensions I designed. Don’t worry about your model, I’m sure it’s fine!
I just want to know what people are using for rehauts. Maybe I’ll have to just print one of those too.
Caboose
1,752
2,570
So I don't think you need a rehaut, you just need to make sure that little bezel spring is in the case back. That's what actually pushes the movement and holder right up flush to the case. If you don't have one of those you could make a flat leaf spring out of a scrap aluminum, literally just a 0.5x1cm piece of aluminum, folded over once.
DesertAdventures
347
62
I have the Pagani case, it didn’t have any spring. My stem is coming in at an angle already and I need to space the movement back off the case a tiny bit. I threw it together late the other night without measuring anything so I’ll check it out, but I saw another user say they had a trimmed repair for their pagani build.
Caboose
1,752
2,570
Take a look here...
See that spring? That's the ticket right there. It works great for two reasons:
  1. When you screw on the caseback the movement holder will not rotate which is good because you don't want it turning and damaging the crown or anything, plus you've got the pushers which you don't want damaged
  2. The spring pushes up the whole movement + holder assembly to the rehaut so there is no gap and the assembly won't rattle
You could even make your own spring with a paperclip, although the thickness of this wire is 0.5mm, and a paperclip would be larger. I've actually ordered some spring steel wire to make custom springs for the caseback of this watch for people to ship out with the movement holders, so they don't have to solve this problem in case they choose to use the Pagani case!
Reactions: Mat_w
DesertAdventures
347
62
Take a look here...
The movement in mine doesn’t need to be pushed forward. It needs a few mm space away from the crystal to keep the stem from being at a big angle
Caboose
1,752
2,570
Very interesting! So in that case you do want a rehaut piece to properly space the movement... In this case how would you feel about designing one for the pagani case? Pretty much a circle I would expect! Or if you have dimensions I am happy to provide the design. I don't have a pagani case to test on but if I did I would be all over this!
DesertAdventures
347
62
I can design it I just didn’t want to put a printed piece in there, would like to find something cleaner. I’ve got enough projects already
Pinion Minion
2,512
9,157
Texas
many of the moonswatches come with a small spacer ring themselves- check and see if one is wedged in the plastic case. hopefully it will be enough.
Which case are you using?
