1675 GMT Project - Milky Case 2.0 review
nyswe
25
Having a slight issue with the v2 case and looking for advice. My issue is that the crystal retaining ring is too loose, applying just some slight force with the fingers to the bezel will pry the ring and crystal right off. I'm using the bezel kit supplied with the v2 case, a GS PA462-19k crystal, and gen insert.
I'm contemplating two potential solutions but would like to probe the expertise of RWI before executing:
1. Glue in place: adding GS hypo cement at the base of the crystal to seal in place and use dots or full string of either GS hypo cement or loctite under the crystal ring to hold it in place on the midcase.
2. Replacing the crystal ring: I remember reading that Cousins (at leas I think it was them) was offering a complete bezel kit with crystal ring, spring, and bezel which might offer a tighter fit - unfortunately I could not find it on their site so if anyone remembers where to buy the kit I would appreciate some guidance
Has anyone had any similar issues and what was your solution?
Thanks
WatchN3RD
682
835
I'm working on this Milk v1 and currently have a v2 retaining ring on it. I haven't checked for water resistance yet, but I have a few crystals to try before I finalize the build. I'll update if any other crystals I have seem to fit a little more snug.
I've also had good results using UV glue for gluing crystals that weren't tight enough for my liking. Worth considering if you just want it glued for water resistance.
Hec
| SELL ME YOUR 6542 SERPICO |
1,024
4,074
Spain
I used Sternkreuz Crystal in milk v2 and not problem.
Your watch looks nice
Dial source? Thanks
Reactions: nyswe
rangan
843
240
insert from?
WatchN3RD
682
835
Dial source? Thanks
Thank you for kind words! The dial is one I made with toner transfer, but it's a separate ongoing project. I've done better, but I used this one to get my build complete. It's decent, but it's finish is not good enough for me to be completely satisfied. It works well as an old one with some damage though.
I'm not sure which crystal I used here, but it's one of the two in the middle.
WatchN3RD
682
835
I just tried the 2 of the remaining crystals I posted earlier on a Milk v2 case and bezel. The 302.450 was extremely tight. It fit the case, but it was tight enough to where I would be worried it would start cracking in the next few days. Bezel would not fit over the crystal even a little bit.
Whichever crystal I didn't use (that was one of the two in the middle above) was very loose.
I know it's not an issue with the Milk case. But like most vintage cases, it's always a mess finding the right crystal to fit both the rehaut AND retaining ring.
I'm going to suggest the 300.158 if you can get one cheap without crazy shipping prices. By process of elimination, I'm 75% sure that's the one that worked for me.
Sorry! I wasn't trying to give such a crappy answer!! I only meant that I didn't have detailed specifications right now, so if you were dying to get your watch done, make an educated gamble on the 300.158.
Reactions: nyswe
nyswe
25
Thanks for the suggestion, UV glue might be a good option if I need to resort to a glue-based solution
Thank you, much appreciate you taking the time to test the crystals and respond with your findings! I will source a xs300.158 and try it, my worry is that the GS462-19k is 30.28mm in outer diameter, the xs300.158 is 30.0 and my retaining ring is ~30.08. However given you and others seem to have had success with the 300.158 I will explore that as an option.
rangan
843
240
The insert is from an Asian seller I found on eBay, but he doesn't really list them. I need to contact him to see if he has any more.
Thanks for the reply , if you can kindly post the link of ebay?
infinito_II
198
42
One question. Google Translate doesn 't work on this page...
1) Milk V2 does needs works on cg?
2) for glass so Sternkreuz XS 300.158
3) for crown.....
@WatchN3RD please:
your amazing 1675 which combo?
Dial Yuky Mk5?
Thank You
WatchN3RD
682
835
3) for crown.....
@WatchN3RD please:
Dial Yuky Mk5?
Thank You
1) The Milk v2 doesn't necessarily need work on the crown guards, but some people may reshape them for a specific look. They are a good amount smaller than on the V1 and are slightly polished. It's a good trade off for most, but it's hard to make them sharper if you wanted a New Old Stock look.
2) I'm not sure what crystal, but I think I used the 300.158. I'll need to find a spare and measure it to confirm. There's a chance I used the 462-18F so I'm not 100% positive.
3) For the crown I have used generic replacement tubes with both generic crowns and genuine crowns. All 5.3mm.
What exactly is your dial question?
WatchN3RD
682
835
I just found a spare 300.158. It fit the Milk v1 pretty snug, but it was a comfortable snug -- a not let water gush in type of snug.
-In comparison, "The 302.450 was extremely tight. It fit the case, but it was tight enough to where I would be worried it would start cracking in the next few days." The 302.450 has already started to crack... I don't think it made it 24 hours before the first crack appeared. Just confirming it doesn't work here.
- I just tried a spare 462-18F, and it fit extremely loose on the rehaut. I tested with a genuine sized retaining and that was also very loose. Not a chance it will work without loads of glue on the rehaut and retaining.
I'm now extremely confident the 300.158 is a great fit and also the same one I used on my watch in the earlier post.
It's not fully seated because I was only checking fitment and putting it back in the bag, but here's a picture or two of the 300.158 fitment.
Hec
1,024
4,074
Spain
Good input, IMHO 300.158 fits decent in the milk v2 case (I have the milk v2 and the 300.158), the problem I imagine some of you know is the position of the cyclops (it should be more towards the outside).
Maybe there are generic glass alternatives that fit well and the cyclops is well positioned
Reactions: WatchN3RD
WatchN3RD
682
835
Excellent point, but when I look at my watch, it is always off center. For instance, if the center pinion was a laser, it would just miss my forehead and burn a hole in something above me. So, I'm not overly concerned about an inward cyclops or one that is actually a little lower than perfect. I'm likely scarred by previous disasters of trying to find a plastic crystal that fits both rehaut and retaining ring on a vintage watch.
nyswe
25
Thanks, appreciated. I have the 300.158 incoming during the course of next week. Will report back with confirmation/findings if any :)
nyswe
25
Received the 300.158 yesterday and it was a good tight fit. The plexi sealed well on the rehaut creating almost a vacuum seal. The retainer ring required some force to mount so now it sits tight as a rock. Only downside is, as mentioned before, the cyclops being a bit to close to the center of the dial and not centered above the date.
All in all I much prefer this option not having to be afraid for the bezel and plexi to fall off during the day.
Thanks everyone for the help!
Reactions: Hec
WatchN3RD
682
835
Excellent to hear! I was only 75% confident at the time you ordered.
Can't believe I forgot... I also ordered another crystal on the recommendation of another member here. It doesn't have the iconic bevel around the edge like the 300.158, but there's a slight bevel with a perfectly placed cyclops.
I prefer the shape of of 300.158, but if a perfect cyclops placement is more important, this one is closer.
nyswe
25
Thanks for the information on the 25-116, I’m looking to order from the same vendor for another build som light as well order a spare and try it on :)
