ARF GMT 116710 SH3186 photo review
botsyboy
3,210
2,289
U.K.
Reactions: m5smg2
rabl253
262
205
Where are you guys sourcing all these gen crystals? Ebay?
2nova2 what size are your wrists? I've got 6.5 " wrists and I'm thinking about this for my next watch, looks great on your wrist proportions-wise (and in general)
McDuck888
3,245
1,827
Chrono24 has been great for my Xtals rabl253. When you use the search bar just select ‘parts’ rather than ‘watches’ from the search tools drop down menu
Reactions: m5smg2 and rabl253
RiffRalf
911
749
Gen crysrals show up on the m2m sales board also. That's where I found mine
37,415
79,555
My date looks like that on the 15th, wait till you see the dates after the 20th. Oh boy those are some thick numbers :laughing:
Yes indeed. DW has not changed, nor has the unparallel cyclops horizontal edges. Sorry bro, but I'm betting you'd take care of that anyway (or not worry about it as it's really a minor flaw that's on them all in this batch).
Goon3r
Reactions: immortalchef
Goon3r
97
34
Cheers for the heads up KJ2020 there are definitely versions of this watch floating around without this issue though. See my essay in the other thread.
37,415
79,555
Does the gmt mechanism work properly? Usually the gmt hand don’t follow the hour as u set up..
The SH3186 movement functions exactly like the gen with regard to hands movements and date flips. Forwards, backwards, everything. The rep movement isn't as reliable or robust as the gen of course and can benefit from the addition of some gen parts, particularly regarding GMT functions and the autowind reversing gears.
johnlia
Watchlover
23/1/17
823
46
Definitely but what I meant is if you set up the hour hand at 12:00 and gmt at 3:00 you will see turning the crown clockwise that the gmt hand will not show a 90 degree angle ????
37,415
79,555
The GMT hand is on a wheel that rotates at half the rate of the hour wheel. There are two complete rotations of the hour hand for each one complete rotation of the GMT hand. So there will never be two exact angular relationships between the hands in a 24 hour period.
This is true for most GMT movements rep or gen, whether the GMT hand is independent or not. There are some Pam's that have an extra "GMT" hand that rotates at the same rate as the hour hand. I think it's a stretch to call these GMT models.
Reactions: Watch-Out
Hazing
And So It Begins... Again
9/5/19
5,188
4,474
I don't know what it is but the arf "2's" (especially in the twenties) look strange to me. On every model.
Reactions: m5smg2 and KJ2020
Mark1937
4,431
3,950
Goon3r
I don't understand you bro. Wich is the problem on this batch?
37,415
79,555
The cyclops upper and lower horizontal edges are not parallel, they diverge. It makes the cyclops look like it's crooked but you can't fix it by rotating the crystal. Yours is not as bad as some others but they all seem to have it.
