Work in progress for hulk!!!
Smoke
14,093
2,220
Mine is getting there. Dial has now been cut to fit the case :)
Sent from my iPhone 6s Plus using Tapatalk
Boom thats the bp myota dial.johnny has the 28 dial.the bp myota hulk dial is simular pop to the v7 hulk dial but has the best layout.and I think the pop looks nicer on the bp dial vs the v7 dial.but cutting g the dial down is a hasstle.so I may just stick with the v7 dial
Versaceboy54
I <3 DD’s
2,249
116
Boom that the bp dial.jonny has the 28 dial.the bp myota hulk dial is simular pop to the v7 hulk dial but has the best layout.and I think the pop looks nicer on the bp dial vs the v7 dial.but cutting g the dial down is a hasstle.so I may just stick with the v7 dial
Yea I was told it wasn't a very easy task to cut and there is also a big risk of messing up the finish bc if any tiny bit of dial shaving lands on the surface it can leave tiny swirls and imperfections.
Johnny Depp
WATCHMAKER
Vendor (Watch Repair)
4,264
4,074
ITALY
is it is great to [MENTION=66637]Versaceboy54[/MENTION]
Congratulations bro!!
Versaceboy54
I <3 DD’s
2,249
116
Thank you bro but I can't take credit for it. I don't have the necessary skill to mod myself like you can!
Johnny Depp
WATCHMAKER
4,264
4,074
ITALY
yours is a SA3135?
Versaceboy54
I <3 DD’s
2,249
116
yours is a SA3135?
No this one is 2836 but I may change to a 3135 later to use with a yuki.
Hopefully noob will fix the issue soon with the sel fit on the v7 case then I will get the 3135 and swap the parts over but for now the 2836 will do.
Smoke
14,093
2,220
You know that bro.he can mod himself. I'm not good enough to do such mods yet.I'm getting there sloooowly ha ha
velox
3,946
245
For a franken Hulk i must say GEN insert and GEN dial "Is A MUST" . . .
Why?
The green rep insert, what ever version it is called can not be replicated to GEN standard/look.
The green colour can be very very close but i can assure you, you can always see the difference even if you are a new noob.
The dial too - the sunburst effect are so hard to replicate - its very different from solid colour dial like the black / blue.
So only these two GEN parts will take you more than $2500 alone. Yes, a very high price (stupid prices to be honest) but to get the perfect franken/genstein or whatever these are a must !
Versaceboy54
I <3 DD’s
2,249
116
All I can really do myself at this point is swap the crystals and change the bracelet and straps for my APs lol
Smoke
14,093
2,220
I can do a tiny bit more than that.but learning is the fun part.I have loads of subs to practice on
Versaceboy54
I <3 DD’s
2,249
116
I agree learning and experimenting is the fun part!
Mosse
DO NOT TRADE WITH ME
6/9/15
1,083
35
when installing the BP miyota so there is need to cut so he could return? I did not understand very well
Sent from the RWI mobile app
Versaceboy54
I <3 DD’s
2,249
116
Yes for the bp miyota dial the feet needs to be cut and also the circumference of the dial needs to be shaved down a few mm bc the miyota dial is bigger then the 2836/3135 dial.
If the dial in question fits the case with out needing to be shaved down then it's not the miyota dial.
Smoke
14,093
2,220
Plus you can clearly see the 28 dial is dull and hardly any sunburst
Versaceboy54
I <3 DD’s
2,249
116
Yes very true.
All bp had to do was make the dial smaller. Why they decided to change the color and the sunburst makes no sense at all.
Mosse
6/9/15
1,083
35
Yes very true.
Ok thank ! But the 28 is better than Noob ?
I ordered my dial by toro, I hope that it has taken the myota. A final question, cut it will not be complicated for my watchmaker ? how must be cut with a cutter?
